Circuit Interrupter trips.
There is a musty smell in our 11,500 BTU window unit and when unit is turned on the circuit interrupter trips and unit goes off. This unit was purchased at a Lowe's store about two years ago. Help!
  • 6,784 Answers
There is some moisture that is leaking near the power supply board in this unit. its a internal leak of some sort. it will need service soon. The musty smell is a dead give away when concerning an internal leak.
Posted on Mar 10, 2009
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Pump will not turn on when button in tub is pushed
Check the pump outlet to see if it is tripped or the breaker if used . These are usually GFCI (Ground Fault Circuit Interrupter) type equipment and are very easily tripped.
Hope this helps.
Bob
Nov 03, 2013 | Crane & Co Crane Plumbing 2430W Whirlpool...
Installing arc fault interrupter with ground fault
If you meant arch fault with ground fault then no, the two types interfere with each other and trip the breaker as one senses an arch and the other grounding.
If you meant ground fault breaker with a GFCI. receptacle, you only need one of the two, either GFCI. breaker or receptacle.
and for circuits, you can put up to 12 devices (i.e receptacle, light)assuming they consume 1 amp each. Anything over 12 amps or 80% of the rating on the breaker, it will trip/reset.
Or if your talking about wires on a breaker then no more than 2 wires recommended. Try adding a junction box outside the panel if your trying to add other branch circuits or tap off of a receptacle.
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
How to replace a Bryant GFCB120 Circuit Breaker
If you have a Bryant load center, you can use other breakers in it, including the Eaton GFCB120 GFI since several companies unified their design. The GFI (ground fault interrupter) or GFCI (ground fault circuit interrupter), same thing, may be required for a device you are installing, such as bathroom, kitchen or outdoor fixtures.
The Eaton series includes very clear installation instructions, but if your problem is that they are missing, then all you do is install the breaker in a open slot in the breaker panel, but you have to attach the neutral [white] wire differently. On regular breakers, the neutral goes right to the ground lug in the panel. With a GFI breaker, it goes through the breaker, and then is connected to the ground lug.
Mar 09, 2012 | Eaton Corporation GFCB120 GFI Circuit...
I have the Kenmoore Microwave Hood 721.80402. During this last wave of storms, I was without power for 2 days. Once the power was restored, the microwave will not work. Everything is plugged in and the...
You might try pulling the plug on the unit and leaving it overnight. The electronics may have locked up due to irregular voltage during the failure. There may also be a GFI (ground fault interrupter) on that circuit that has tripped for the same reason. Check the kitchen outlets for a tripped GFI.
Feb 14, 2010 | Kenmore 62622 Microwave Oven
Disposal does not run. I've turned the appliance
Your disposal unit may be on a GFI protected circuit which has tripped. If you don't have a GFI (Ground Fault Interrupter) in your kitchen, check your main breaker box since they are often installed there.
Oct 17, 2009 | Emerson InSinkErator STS-S0 Sink Top...
Tripping at the current interrupter
It appears your Air Conditioner has ann electronic remote. Has the batteries or something happened to the remote lately? Reason I ask is because your model has a programed circuit board and I need to know if you need to address the remote or the programed control board. Let me know, I can find the parts if you need to fet them, Sea Breeze
Jul 06, 2009 | Kenmore 75101 Wall/Window Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
