Emachine w3052 sempron 3000 Power supply gave off a warning buzzer in the middle of the night and I pulled the plug. Next morning I had no juice to anything. Bought another powersupply and changed it. No juice to anything. Tested the switch in front of tower, it's ok. Changed the lithium battery. Still no juice anywhere. Bought a generic powersupply specified for my model. Now I have juice to all drives and cpu fan but PC won't boot. HD is fine im using it now on this PC. Have it set on master. This new power supply is a switching power supply where as the old Bentec was not. The front switch on the pc doesn't light up blue like it used to. I'm wondering if I need to change anything on the motherboard switch pins or power pins?? I'm afraid it maybe the motherboard but it smells fine and I see no hot spots on it. Am I forgetting anything else???
  • tbelanger213 Mar 10, 2009
    One of you guys mentioned the Rom chip on the Mboard maybe fried,,, I'm assuming that's the 32 prong PMC FLASH chip for the BIOS settings. It is in a sink and looks replacable w/o having to sauder, but Wouldn't I have messed up the settings by repacing the battery as well. If so how would I reset it if the DOS menu doesn't boot either.
  • 6,784 Answers
This is mother board failure. i would pull the board for a visual. try to find any discolorations that may lead you to the problem. the previous pin selections should match up to any aftermarket power supply.
Posted on Mar 10, 2009
  • 10,515 Answers
Yup, that's motherboard.Let me research more and will get back to you in few minutes.
thanks.
  • 916 Answers
It sounds like your rom chip on the motherboard has gone.
  • 13,433 Answers
Hey I suggest to buy a powersupply tester to see if the powersupplys are fine, possibly motherboard faulty.
heres the tester
http://www.google.com/products/catalog?q=powersupply+tester&oe=utf-8&cid=1524379307725350783&sa=title#ps-sellers
  • Ekse Mar 10, 2009
    So you bought a 3rd powersupply and then things started to work again? But the pc is not starting up. I would suggest trying to reset the bios, there is a jumper on the motheboard most cases close to the battery that can reset the bios. Also I would suggest taking out all the ram memory fom the computer. Then turn the computer on without ram memory (ofcourse unplug in the middle) Then you should hear beeping from the computer, turn the computer off. Place one of the memory modules back in.
    Now you should get a start up screen, if not, try reseating the video card the same way you just did with the memory.
  • Ekse Mar 10, 2009
    To reset the bios on this motherboard, you need to pull the jumper and place it back on the other position, let it be for a minute, the computer needs to be turned off and unpluged, the 3volt battery will provide the power it needs.
    Then place the jumper back into its original position, the bios or cmos is reset try turning the computer on.
Looking for a good plug and play cpu to upgrade from the sempron in the emachine t3616
Memory is RAM, not storage space like the hard drive.
The fastest CPU that fits socket S1 is the TL-68, but I wouldn't put it in your emachine because of heat and power consumption. Maybe give a TL-60 a try? They are only $5 on eBay.
Feb 12, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My w3052 emachiens desktop computer card readers wont work
Visit the support section of the eMachine website to get the software that controls that function.
Oct 25, 2009 | E-Machines W3052 PC Desktop
Low battery warning, how do i stop it as it is now the middle of the night and I can't go to a store till next morning?
Remove the battery. If it has a low battery because it have no online power, restore that power. If it has online power and stills complains about not having a battery, cut power to it. If there's a silence or clear button, try that. If it's a monitored system, the company may be able to silence it for you.
Oct 01, 2009 | Kidde Home Security
Emachines W3052 Gets stuck on logo screen when starting up.
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
May 16, 2009 | E-Machines W3052 PC Desktop
Worked one night, next morning would flash on then automatically turn off
Yep, the inverter transformer on the Power Supply Board burned out. It's one of 5 inverters that powers up the screen.
If one is burned out, it will not have enough juice to power the screen and goes into protection mode like it's doing right now.
You'll have to replace the POWER SUPPLY/BACKLIGHT INVERTER BOARD. The cheapest place runs for about $90.
I'm not sure which one you have, there are 2 different boards for that TV. The board number should be in white on your board.
Here's for the BA8AF0F01031
http://www.shopjimmy.com/power-supply-backlight-inverter-ba8af0f01031-from-emerson-lc320em9-5.htm
And here's for the BA8AF0F01032
http://www.shopjimmy.com/power-supply-backlight-inverter-ba8af0f01032-from-emerson-lc320em93-8.htm
It's definitely cheaper than buyig a new TV. That what I did to fix mine. :)
If you throw your old board in the trash, I would like to keep it for research if possible. Here's my e-mail: dsacco86@hotmail.com
Apr 20, 2009 | Emerson LC320EM9 32 in. LCD HDTV
GE SpaceMaker JVM140001 just quit
Same thing happened to our unit. My wife had started cooking potatoes and we left house for an hour. Came back and unit was dead, nothing worked. Verified power @ plug. Unplugged, pulled control panel and checked fuse which is mounted @ top of circuit board (will now refer to as CB), back side of interface panel. It passed continuity test. Inspected wiring and was all intact, no sign of burn thru. Varistor visual also looked good, no discoloration or burns. Removed (5) fasteners that hold CB to interface and inspected back side. Noted minor "blackening" @ pin location #1 of the (5) pin plug immediately beneath fuse. Resoldered because connection looked poor. Plugged back in and tested, all features worked correctly!
Mar 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have emachine w3052. The
The board should have markings indicating where to put the wire. It will probably be abbreviated such as "PW" or something similar.
eMachine Support
Jun 10, 2008 | Computers & Internet
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
315 people viewed this question
David Payne
David Payne
