Question about Garmin nuvi 260W GPS Receiver
My Garmin nuvi 260 won't power on. It should be fully charged, but won't respond to anything.
  • gary994 Mar 10, 2009
    My Garmin nuvi blanks out as soon as the screen with the word garmen comes up. Sometimes it will make it to the Where to Go before it blanks out. Is there a batter and how do you change it?
  • Garmin Expert
  • 343 Answers
Try a Master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 17, 2010
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
Garmin nuvi 200w
reset it with your computer. It might need a hard reset
Jun 02, 2012 | Garmin nuvi® 200 Car GPS Receiver
Garmin gps doesn't work when charging with cigarette charger. Instead of the GPS to Navigate it rather shows like there's a data transfer.
The proper vehicle power cables for the Garmin nuvi 260 are part numbers 010-10723-06 or 010-11478-03.
The use of improper cables will cause the nuvi to go into mass storage.
You may also want to contact Garmin Support for assistance.
http://www.garmin.com/us/support/contact
Sep 23, 2011 | Garmin nuvi 260 Car GPS Receiver
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 19, 2009 | Garmin GPS
Garmin nuvi 260
What you would do is, under where the model code sticker is under is the reset button. remove the sticker and hold down the reset button for 10 seconds at the same time hold the power button towards the left.
May 14, 2009 | Garmin nuvi 260W GPS Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
How long to the initial charge for the Garmin nuvi 260
how long to charge the battery for garmin nurvi 260 initially using the ac adapter?
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Sep 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
355 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
