Question about Apple iMac G5 Desktop
Computer turns off unless constantly using... even put to sleep, it turns off instead.
  • Anonymous Mar 15, 2009
    G5 iMac turns off unless constantly in use. I keep iTunes playing to avoid having computer shut down on its own.
    Novelist:
  • 89 Answers
Hi, Sorry you are having problems,
Sounds to me like either your energy saving preference pane is set WAY too short or it is corrupt.
Go to your system preferences and select (Energy Saver) and be sure it is set to never sleep and set the idle time to screen sleep time to about 30 minutes and be sure the button ( Shutdown instead of sleep ) is not selected... if you have that button.
Try these, then do a restart to be sure they take.
If you still have the same problem, then, your settings are corrupt, you will need to delete it:
go into your hard drive, into your user folder, into the library folder into the preferences folder and find this file:
com.apple.systempreferences.plist
put it in the trash, empty trash, restart the computer the reset your energy saver settings and you should be OK!
Posted on Apr 02, 2009
I heard there was a sleep button. Is this true? And if so, where is it?
in control panel, > Hardware and Sound > Power options > System settings you can set up what your computer will do after you push power button...... you can set up sleep and your problem is solved
it's in Windows 7////... other OS are pretty much same...
Mar 25, 2014 | HP EliteBook Computers & Internet
Compaq q1859 monitor
Hmmm, sleep/suspend mode is only supposed to happen when it doesn't sense any movement from the mouse, it also shouldn't suspend if you are in full-screen either. So if you are playing a game that shouldn't happen at all... as a test you should put the "turn off the display" to "never" and see if it still happens.
I have this happen when watching Netflix, if I don't move the mouse my TV will go into suspend mode, even though I am in full screen... I think my issue however is related to the fact that I am using HDMI to connect to my TV from my computer... I have not solved this issue yet!
Oct 15, 2013 | Computers & Internet
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
My mac computer keeps putting itself to sleep
It may be that the computer is overheating. Are you using the computer on a bed or other soft surface that might be preventing the computer from cooling properly?
Jan 21, 2012 | Computers & Internet
I hate this drive a want to pull the Hard drive
Basically it was ugly. The drive enclosure wasn't easy to open and got destroyed.
However, on the Bonus side, I was able to pull the drive out and put it into another enclosure and now it doesn't go to sleep unless I say so. HooRay!!
Sadly it isn't on FireWire anymore but on a much slower USB2. But I'll take the USB over the aggravation of the drive constantly going to sleep. It's easier but buy a FireWire enclosure than stopping the sleep cycle.
I don't want to EVER see a Maxtor OneTouch Plus 4 1TB in my office ever again.
Jan 03, 2010 | Computers & Internet
Computer won't use sleep mode anymore
Go to Advance Power Settings.
Set hard drive to turn off a minute or 2 before sleep.
Set Hybrid and Hibernate modes to "Off"
Under USB settings select "Disable"
Under Multimedia select "Allow ....." also setup your screen to turn off ( pick how long monitor will stay on. you can also try going into the bios and setting it to default. save and reboot. let me know if this helps.
Nov 13, 2009 | HP Pavilion S3420F Slimline Desktop PC
1 TB is beeping
After doing some research it seems the beeping means that there is a disk failure.
Prop off the front of the unit, remove the drive and replace it. The unit will automatically rebuild the drive, which takes about 8 hours
Jul 15, 2009 | Buffalo Technology 1TB DriveStation...
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
Computer will not stay in sleep mode. It reboots in about 10 seco
The PC comes back out of the sleep mode by input from the keyboard, mouse, or if it's configured in the BIOS, by the network card. If you are connected to other PC's, the network card might constantly be passing info back and forth throughout the network and then it won't remain in the sleep mode. First thing I'd do is check if there is a setting in the BIOS which makes the PC come out of sleep mode by the network card.
The mouse and keyboard can also be pretty hyper. You can sometimes just sit in front of your PC and blow air onto your mouse or keyboard and the PC reacts. Therefore, if you have your PC in a room with a slight draft, it might help to keep the doors & windows closed. Any small vibration may do the job, so make sure the table isn't on top of something that vibrates, even if ever so slightly.
Mar 13, 2009 | Gateway 505GR PC Desktop
Apple iMac G5 Desktop Logo
290 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
