Question about Goldstar DH3010B Dehumidifier
Fan motor stopped working, replacement went out too!
My fan motor quit working so I replaced it, I installed the new motor and it seemed to run fine. About an hour later I checked on things and the whole dehumidifier was hot, the compressor felt very hot and the motor was also extremely hot. The motor was inoperable. After letting the machine cool for a day, I tried it again, the compressor kicked on but the fan motor failed to start. Any ideas?
  • pjdan Mar 23, 2009
    Fan motor ran for a short time but at a very low speed/level. Everything then just stopped and it got very hot to the point where I unplugged it.
    Guru:
  • 462 Answers
I would look for another outlet for you to plug it in before you start anything elaborate. I assume you've done this already but spin the motor/blade. If it spins and there is little or no play in the shaft or blades causing a blade to bind up the mechanical part seems ok.
Now if you have a volt meter First check the motor for voltage, Then if you have voltage, compare it to the rating on the motor. Usually a voltage within 10% is ok. Next test resistance on the wires of the motor any resistance and the winding is probably okay. If not then the motor is out again. If you have lost voltage the control board is your next part to test. No voltage out to the motor there on the board plug and the board is the problem Power there woudl mean the motor has too high a resistance and Id check the resistance on a differant known good motor before replacing it. just so you know where you started.
Posted on Mar 10, 2009
I have a Kenmore 54701 Dehumidifer that quit working is there any thing to look for or just throw it out and buy a new one
Is it not powering at all? Remove cabinet and check glass fuse on power supply board
Is it running but no water?
Check to see if fan is blowing; if not then thermosenser on fan motor blown
Fan and compressor running but no water? Maybe the room is already dry; if not than probably have coolant leak - not worth fixing
Dec 04, 2009 | Kenmore 54701 Dehumidifier
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
MY unit has become increasing noisy and the fan is the mane cause. The fan is now making different noises at differing levels high and low of loudness, and it often quits running all togetger. It is also...
It sounds like the bearings in the motor are worn out, especially as you said it quits running at times. You should be safe in just replacing the fan motor, but check the fan blade to make sure it isn't out of balance for any reason(dirty, missing a balance weight, or bent). Hope I was of assistence!
Nov 14, 2009 | Kenmore 53701 Dehumidifier
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 31, 2009 | Dehumidifiers
Fan not working
Jul 31, 2009 | Fedders A7DH65B2A Dehumidifier
Electrohome dehumidifier stopped working
I have no experience of your particular machine but I have some experience of my Wood's DS-15, another fine machine of the compressor type that is built to last. They should be rather similar in design.
My first thought when I read your problem description is that you have a severe buildup of dust inside the machine. On the Wood's, you loosen the front grill and behind it you will see the fan, behind the fan is the condenser pack, and then you get to the evaporator coils that are visible from the back of the machine.
Maybe the configuration is slightly different on your machine but they are built very simple these machines, easy to see what they need in order to work as designed and you already know the most central and expensive parts seem ok.
I had some problems with low efficiency on the unit after six years daily service in a laundry room for drying clothes, took it apart and couldn't believe the amount of dust that was packed into the fine fins of the condenser on its back side! Also extremely much dust on most components like the fan.
I just took it outside and blew it clean from the front side with compressed air, problem solved and machine performance went back up to where it was when new!
I would imagine after a few more years of dust buildup inside, at one point or another the dust will reach the fan and prevent it from spinning. It is also possible of course that the fan motor is shot but I'd start with a really good cleaning.
If that doesn't help I'd continue with the multimeter see if the humidistat gives power to the fan and compressor when it should, if the fan actually spins when powered, if the switches work. It should be quite easy to track down the reason the fan doesn't spin, IMO. I believe you can buy replacement humidistats and motors if they turn out to be faulty.
May 26, 2009 | Dehumidifiers
Kenmore Dehumidifier
I wonder if a little squirt of WD40 would go a long way in preventing the rust problem?
Sep 01, 2008 | Kenmore 54701 Dehumidifier
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Fan not working
You can purchase a new fan motor. But the same problem will probably happen again. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a yellow thermistor or type of temperature sensor connected between the red wire and a motor winding wire. On my motor this was no longer working (in effect it was an open circuit). Once replaced the motor worked fine. this is the second time in about two years that this problem happened. The first time Sears fixed for about $100 and three weeks. This time I saved the money and did the repair myself. I would guess you could buy a new thermistor for about $5.00 from a parts house like digiKey or National Electronics. You will need to know how to use a soldering iron to repair this.
Jan 18, 2008 | Kenmore 54701 Dehumidifier
Goldstar DH3010B Dehumidifier Logo
318 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
