Question about Kenmore 46462 Front Load Washer
Everything works but the spin cycle does not come on at all. You can hear the switch moving to the different cycles but the spin does not activate.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Everything works but it does not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
My maytag atlantis washer purchased in 2002 would not spin on the colors spin cycle. I turned the control completely around to the spin cycle and tried again and it didn't work. I also set it on the spin...
Jim, I would be looking at the lid switch assembly. Try to press down on the lid in the very front edge. IF the switch is going out of tolerance, the added pressure will activate the switch and allow the machine to spin. If it were a transmission problem, you would hear the motor. (I'm assuming you are not hearing the motor).
If you are hearing the motor run, check the motor slides to make sure they are not rusted and the motor is able to pivot back and forth freely.
Let me know if you have any other questions on this!!
Aug 19, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Anyone anygood troubleshooting a Whirlpool Washer?
Thats a problem. Did you have the washer laid on it's side when moving? Timer switch would be first look. Hot water not working,but cold is? Mmmm.. Water inlet is pretty simple no real mechanical parts except intake valve for each inlet. Valve could be plugged or stuck closed on hot intake. Temp switch could be bad and that would cause the water intake to shut.I guess, but not usually a problem unless old machine. Make sure the fuse in control panel is intact. Underside of washer is a relay switch called wigwag. If it is bad nothing will cycle, easy fix 10 minutes and $15 in most cases. But check out before jumping to solve. All ways check cheapest parts first. Lid switch would also cause the no start and spin cycle problems.
Mar 09, 2010 | Washing Machines
Maytag washing machine (PAV3240AWW) does not do the spin cicle
this could be a couple different things. if it stops at the spin cycle, and makes no noise at all, you need to check the lid switch. if you open the lid, the lid switch is on the right toward the rear. there is a plunger on the lid that activates the switch when you close the lid. if the switch is bad, or the switch housing is broke, replace the switch. be sure to make sure the plunger on the lid isnt broke, and not going in far enough to activate the lid switch. if this all turns out to be ok, it could be the motor slides or jammed pump bearing. you would no if it is one of these if when it gets to the spin cycle, you hear the motor run and it doesnt spin. the motor pivits on slides to one spot to aggitate, and to another spot to spin. sometimes these slides get dry and you just grease the slides and the motor plate so the motor can pivit again. if it is the pump bearing, you will hear the motor and smell "burning rubber". if this is the case, replace the pump. let me know if you have any questions, good luck. shane
Sep 01, 2009 | Washing Machines
My whirlpool does not work in the spin cycle
Check the spin cycle activation switch located on the lip of the machines casing where the lid comes down to close.
Often the switch that activates the cycle either goes out and simply needs replaced. Or has worked loose from it's bracing and when the lip comes down to make contact { push it in } the switch body shifts and doesn't receive enough pressure to activate the cycle.
Replacing the switch is both easy and inexpensive if you replace it yourself and avoid a tech service call that would generally cost more than the part itself.
Jul 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Whirlpool washer machine will not spin when the rinse cycle is activated, I hear the switch moving as soon as it starts to move it cuts out...
spund slike a lid switc issue, try opening and closing the lid a few times and as you do listen for a distinctive "click " noise rigth before the lid closes, if you dont hear tha tthe machine is not recognizeing that the lid is down as for safety reasons will not advance to drain/ spin mode. if this is the case youlkl need to replace the lid switch assy
Apr 02, 2008 | Washing Machines
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
