Question about Hanns.G Corporation HU196D (Black, Silver) LCD Monitor
I connectedthe hanns-g hu196dmonitor to ps3 black screen appeare
I tried to connect the hanns-g hu196d monitor to my ps3 via dvi to hdmi out i switched off my monitor and then put it back on and it asked me weather to switch to digital which is the ps3 connecting with dvi i cliked on digital and only a black screen came up nothing else plz help
Saigua
  • 981 Answers
SOURCE: Monitor displays white screen when connected and powered.
Does the OSD settings menu work or (say, contrast) controls work? It could be a control circuit that somehow gets as far as switching the backlight on but can't get the video detection or further (resolution data interchange, etc.) stuff going. There might be a reset jumper for that somewhere in the monitor, or via holding Power for a few seconds, or a Power/brightness-down combo.
Without going to open it up for reset and test connections; there might be a utility (if you can borrow another monitor to get it going) supplied with the monitor to provide settings for it from the PC end! Wacky, but true.
Posted on Feb 23, 2008
  • 105 Answers
SOURCE: hdmi to dvi
This message may occur if the signal from the video adapter exceeds the scan range of the monitor (monitor not HD enabled).
The video adapter setting on PS3 for updating the screen (the refresh rate) is incompatible with the monitor.
Posted on Mar 28, 2008
SOURCE: HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
I have the same problem. I leave the computer on for awhile to warm up the screen. I don't know why, that seems to help. I turn off the screen on the bottom right and do that a couple of times. Behind the screen I unplug and plug and unplug and plug the screen in again. After it gets going, it works all day. But at night I like to turn off the computer to rest. So I have to do this every morning.
Posted on Mar 26, 2009
  • 916 Answers
SOURCE: trying to hook up to ps3 using HDMI to DVI cable
Hook up the PS3 so you can see the screen. Then go into the display settings and lower it to the lowest resolution settings. Then try connecting it again.
Posted on Sep 07, 2009
SOURCE: Blank Screen using HDMI-DVI cable for PS3
i have my ps3 settings on default settings but i no longer have my red yellow white cords, just the hdmi cord. i need guidance setting it to hdmi on a blank screen
Posted on May 13, 2010
My monitor(HPL1950) was working good until i unplugged it to play on PS3. When i connected the monitor to my PS3 with HDMI it showed black screen. There is photo showing the screen. Help please
If your cennecting using an hdmi to dvi then you might want to check that your ps3 is only sending video and not video and sound as not all screens have a dvi port that supports sound and dvi. Also it could just be a resolution issue. Try having the resolution of your ps3 to 720 or possibly lower and see what happens. Then if all good work your way up to find what your monitor can handle.
Nov 07, 2015 | Video Game Consoles & Games
Screen keeps displaying "adjusting...."
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
Hy all and thankyou for read this! I have a
Go to your run command and enter msconfig and hit enter. then > startup and in the listing of items un check the line that has anything to do with your video card/software.
Sep 08, 2017 | Hannspree HANNS?G HU196D Monitor
Please tell me where find drivers for my monitor "Hanns-G,HU196D" i dont find this. Please send me or write me links directly. Thanks and good luck.
Monitors don't need drivers, video cards do. You will need to find out your exact model of video card by running this program:
http://www.piriform.com/speccy
then go to the site of its manufacturer and you will find its exact driver there, in the Downloads section.
Oct 05, 2010 | Hanns.G Corporation HU196D (Black, Silver)...
"out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | BenQ T221W Monitor
Trying to hook up to ps3 using HDMI to DVI cable with Hanns G 174D monitor. CAn only see blank screen, any solutions?
Sep 07, 2009 | Computers & Internet
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
Sep 20, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Hdmi to dvi
Mar 28, 2008 | Computers & Internet
Hanns.G Corporation HU196D (Black, Silver) LCD Monitor Logo
282 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
