Message says...."error message 50.2 Fuser Error turn off then on"
  • clm3 Mar 10, 2009
    Can I install a fuser?
    President:
  • 1,314 Answers
You need to replace the fuser.
Posted on Mar 10, 2009
  • Kevin Shafer
    Kevin Shafer Mar 10, 2009
    Yes, it is a user installable consumer part. I am assuming you have an HP printer. If you order a maintenance kit, it will include the fuser as well as rollers because chances are if its time to replace the fuser, its time to replace the rollers as well. The kits will have instructions included with them.
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
Turn off the product, wait at least 25 minutes, and then turn on the product.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
Hp laserjet 3055 has error message on copying "50 fuser error, turn off then on". Restarting brings on the same message when copying.
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the cabling connections to the heating element.
4. Turn on the power and wait for the all-inone to initialize.
5. If, the error persists, replace the fuser.
NOTE The device power mustremain off for at least 20 minutes forthe fuser to cool down and correctly reset.
Turn off the power switch, wait at least 20 minutes, and then use the power switch to turn on the all-in-one and wait for it to initialize.
Aug 23, 2011 | HP LaserJet 3055 All-In-One Printer
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
I'm tyring to print this morning and message comes up need to order supplies, then I look what I need and change it but this message error keeps coming up 50.2 fuser error before and after I change the...
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Aug 23, 2010 | HP LaserJet 2840 All-In-One Printer
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
We have a Canon IR400S with the following error message - Switch main power on & off, E005. Switching power on & off did not clear error. Can you tell me what the error message means?
The error message means that the Fuser web has a problem. This is the part that cleans the upper fuser roller on the copier. It's located inside the left door of the copier and more than likely requires a copier technician to replace it. Fuser webs(belts) gradually get consumed after about 100,000 prints. The other possibility is that you may have had a brown-out or some other kind of power fluctuation in your area and the error just needs to be reset in service mode, but I'd check the first solution 1st, the part is cheap $25-$50.
Dec 10, 2009 | Canon Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
14 people viewed this question
k24674
jasbo
jasbo
