Question about Apple eMac G4 Desktop
Slow running mac
Slow switching between applications on eMac 10.3.9
  • 14 Answers
There are a number of reasons that may causing a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more the solution here: http://www.howtospeedupmac.com/
Posted on Jun 22, 2012
  • 558 Answers
Have you thought of upgrading the memory or the prm?
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Good Luck
Posted on Oct 17, 2009
Cant download flash to emac
The eMac uses a G4 processor, and is limited to Mac OS 10.5.x. The most recent version of Flash Player that will run on it is Flash Player 10.1 (if you are running OS 10.4 or later), or Flash Player 9.0.280 if you are still running OS 10.3.
Note that not all web content will work these older versions - in particular, Facebook video inserts will incorrectly claim you don't even have Flash installed instead of playing!
Apr 11, 2012 | Computers & Internet
I just got a used e-mac A1002 (1 Ghz/128/60/combo 56K. It has Mac OS X 10.3.3 installed. I'm having problems signing into G-mail. Facebook also appears as just text. As well, can't seem to play...
I would try and find the OS X Tiger installation disks off of eBay, and install Tiger so that you can at least install Firefox, even if it's an older version. Your computer won't be able to run much, because of the limited RAM, and the fact that the processor is extremely slow.
Aug 03, 2011 | Apple eMac Desktop
Emac won't start up
An Emac! one of my favorite CRT Macs :D
They sometimes had a problem of the vibrations of the speakers killing the CRT Tube. But it sounds like you are having worse problems.
the first suspect would be bad ram. Try removing one stick, then the other and running it with only one stick. If you only have one stick, then get ahold of a new stick and try that. There is a little rectangular cover on the bottom of the computer that your ram hides under.
If that doesnt fix it, return any purchase of sticks or ram and lament the death of your mac. Not that it is not fixable, its just cheaper to get a new one, and hey, unless your hard drive is fried, you can even get all your data off! How cool is that?
DISCLAIMER: You are dealing with a CRT (Cathode Ray Tube) Monitor. It can and will shock you if you touch the wrong bit. Possibly even lethally. EVEN if it is unplugged. If you dont feel comfortable opening the case, pay a professional.
Here is a link showing how to take apart your mac. http://www.wilko.com/emac/
This also has a good picture of the memory cover.
Once you have the hard drive out you can get and IDE to USB cable or hard drive enclosure, and hook your old drive up to your new mac, and use the migration utility (in the utilities folder) and pull your whole account (applications and all) to the new mac.
You can get a 1.4GHz Emac for around $200 these days.
Apr 23, 2010 | Apple eMac G4 Desktop
Problem with Emac
You may need to reinstall you OS or run setup utility to correct disk permissions with your installation CD that came with the computer.
Jul 20, 2009 | Apple Computers & Internet
My emac is verry slow
Hmm can be any number of things - how many programs do you run at the same time? Do you have lots of dahboard applications running? Is your hard disk severely fragmented? When is it verry slow?
Jul 05, 2009 | Adobe Computers & Internet
Ethernet speed changes from normal to zero
If you have high speed internet go to your ISP webpage and do a speed test. If You are paying for say like 10 MEGS and are only pulling 1.2 Megs. It probably is your modem. Your speed will slow down to approx 7.5 behind a router. Also Your ethernet cable might need replacing. might also might try resetting your router. disconnect all power even the cable comming in and reset everything. Hope that helps.
May 24, 2009 | Apple eMac G4 Desktop
My eMac seems to get slower and slower all the time. Using version 10.3.9 and whenever I switch between applications it spins.
You will need to check for BAd caps on this look under the memory lid and see if the caps are bulging if they are you got a emac that is failing and you would need to send it in for repair you can take your logic board out as i did http://www.photospace.com/rss_feed.php?rss_id=3354 look at my pics look at the caps the round thigs there bulging this means they need to be replaced so I am going to try it myself but you can take it to www.badcaps.net this guy will do it for under the price it would cost for a new logic board.
Mar 10, 2009 | Apple eMac G4 Desktop
EMac G4 700 512
try to download adobe flash player installer for MAC..
Jan 31, 2009 | Apple eMac G4 Desktop
EMac sound will randomly go to FULL BLAST
If you don't get it fixed, try hooking up external speakers. The external speakers have a hardware switch that prevents it completely from going to the built-in speakers.
Jan 27, 2009 | Apple eMac G4 Desktop
Apple eMac G4 Desktop Logo
289 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
