Question about Xerox WorkCentre M15i Laser Printer
Display screen indicates "no paper" incorrectly
Display screen indicates "no paper" and will not print. It does have paper. Have checked all areas, ports, etc, to no avail. help
    President:
  • 2,072 Answers
When you remove the paper tray, is there a black actuator flag hanging down in the paper path? that tells the machine the tray is in place. You can remove the tray by pulling it out, and lifting up and out on it and lift that actuator up and down . If the message does not clear you have to replace the sensor on the paper feed assembly, That is not an uncommon part to fail.
If you need a part, I would recommend you google "the parts drop" and give them a call for what you need.
Posted on Mar 11, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Tray falure loading papers
Paper jam at the drum area. Are you printing to this machine ensure the print properties equals what is a the machine Landscape paper not portrait vise versa. Ensure machine not set to metric size paper vise Inch in the USA
Mar 20, 2014 | Minolta DiALTA Di183 Copier
How to do a print test on canon mp460 printer after replacing cartridge?
Print the nozzle check pattern to determine whether the ink is being ejected properly from the FINE Cartridge Nozzles. Use this function when the printed results are blurred or the color is incorrect. sikaku.gif Performing Maintenance 1 Press [ON/OFF] to turn ON the machine.
2 Press [Menu].
3 Display the Maintenance screen.
(1) Use [l_mark_s17.jpg] or [r_mark_s18.jpg] to select <Maintenance/settings>, then press [OK].
The Maintenance/settings screen is displayed.
(2) Use [l_mark_s20.jpg] or [r_mark_s21.jpg] to select <Maintenance>, then press [OK].
The Maintenance screen is displayed.
(3) Use [t_mark_s23.jpg] or [d_mark_s24.jpg] to select the setting item, then press [OK].
The setting screen for the selected item is displayed.
sikaku.gif Printing The Nozzle Check Pattern 1 With the machine ON, load a sheet of A4- or Letter-sized plain paper in the Auto Sheet Feeder.
2 Print the Nozzle Check Pattern.
(1) Display the Maintenance screen.
(2) Use [t_mark_sas25.jpg] or [d_mark_s26.jpg] to select <Nozzle check>, then press [OK].
The pattern print confirmation screen is displayed.
(3) Use [t_mark_s28.jpg] or [d_mark_s29.jpg] to select <Yes>, then press [OK].
The nozzle check pattern is printed.
Mar 31, 2010 | Canon PIXMA MP460 All-In-One InkJet...
When printing I am getting a paper width error
The print job you are printing is wider than the paper, or the pritner is detecting the edge of the paper incorrectly.
You can disable the Paper Width Sensor, but it means that any data which is printed outside the paper area will be lost. You may also print on the platten which may reduce print head life.
I would recomend checking the width of the print job or paper size set on the system.
The paper width sensor can be turned off in the following way
Start with the printer power OFF
Hold down the ONLINE button and power the printer ON
Keep the ONLINE button held down until the display reads TEST MODE then release the ONLINE button
When the display reads ASCII80 ASCII136 press the button under BACK (button 1)
The display should read APW, if it does not keep pressing button 1 until it does
Press the button directly under APW (button 2)
Press button 2 (under the <) to change the setting to read APW=OFF
Press the button under SET (button1)
Press the ONLINE button to exit this test menu, then power the printer OFF and back on again
Once the APW has been set to OFF it is then worth testing the printer to see if this resolves the error.
Feb 18, 2010 | Tally Matrix T2280 Printer
On my 2265+ I will be printing and I recieve "paper width error" press online to continue
The "paper width error" indicates you are printing out side the area of the paper. ie the document you are trying to print is wider than the physical width of the paper you have in the printer.
The printer displays this error to give you the opportunity to remedy the problem as printing outside the area of the page may be undesirable;
  • Data printed outside the area of the paper will be lost, you will not see this information you printed on the paper.
  • You may shorten the life of the print head by printing on the platen with no paper to protect the print head.
I would recommend the following;
  1. Check the size of paper selected on the computer system, or ensure the data print width is the same or smaller than the actual paper size used in the printer.
  2. If it is not possible to change document size on the system or if the printed outside the paper width are not required or are simply spaces (ie no print) you may wish to turn of the paper width sensor so the edge of the paper is not detected and the error is no seen, the paper width sensor can be disabled in the following way.
  • Power printer OFF
  • Hold down the ONLINE button and power the printer ON, keep the ONLINE button held down whilst the printer powers on and initializes.
  • Release the ONLINE button when you see ASCII80 and ASCII 136 along the top line of the display.
  • Press BUTTON 4 (under NEXT) repeatedly until you see the APW option along the top line of the display.
  • Press the button directly under APW
  • Press BUTTON 2 or 3 to toggle the APW setting to OFF
  • Press the button under SET (button 1)
  • THen power the printer OFF and after a few seconds back on again.
The above actions will disable the Paper Width Sensor and you will no longer see the Paper Width Error, be aware you may be losing data and or shortening the life of the print head.
Jan 07, 2010 | TallyGenicom 2265+ Matrix Printer
My pixma ip8500 is printing with some colour missing, all cartridges have ink in them?
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 01, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Canon IP 90 clogged printhead nozzles. How to remove printhead?
To avoid drying of the Print Head and clogging of the nozzles, note the following.
*When you turn off the Machine
Follow the procedure below to turn off the machine.
1)Press the ON/OFF button to turn off the machine,
2) Confirm that the POWER lamp has gone out.
This takes a few seconds or as long as 20 seconds.
3) Unplug the power cord from the wall outlet.
If you are using a power outlet strip, you can switch off instead.
When you press the ON/OFF button to turn off the machine, the machine automatically puts a protective cap on the Print Head to prevent the ink from drying. If you remove the power cord or switch off the power outlet strip before the POWER lamp goes out, this capping will not be done properly, causing the Print Head to dry and clog.
* When You are not Using the Machine for a Long Time.
When you are not using the machine for a long time, print or copy in both black and white and in color or pertorm Print Head Cleaning, about once a month to prevent degradation of the Print Head.
Numerous nozzles are installed in the Print Head for high -precision printing. Just as the uncapped tip of a ballpoint pen or marker becomes dry and unusable if it is not used for a long period of time, the print nozzles becomes blocked by dried ink. Periodically printing or cleaning of the Print Head can prevent this blockage.
Note :
*If the printed area is traced with a highlight pen or paint-stick or stained with water or sweat, ink may blur depending in the paper.
*If the print head nozzles get clogged , printouts will become faint or particular colors will not be printed properly.
1)
Hope this helps.
Thanks.
Have a good day.
Nov 30, 2009 | Canon PIXMA iP90 Mobile Printer
Paper jam when trying to print envelopes.
You need to make sure that your print sriver setting match the setting on the printer itself.
If setting are changed on the printer itself to envelopes then when you go to print click preferences button on print screen and look for a place to change paper type (usually defaulted to letter size.) Change paper type to envelpoes and click ok. Click ok again on print screen and it should print correctly.
Paper types must be configured the same on the device as well as the print driver installed on the computer.
Hope this helps
TankMurdock
Mar 09, 2009 | HP Photosmart D7260 Printer
My printer display incorrect paper size and stop printing
Try checking that the paper size settings in your printer driver ar set to either 'AUTO' or to the paper size that is being fed thru the printer. Let me know?
Nov 22, 2007 | Canon imageCLASS D320 Digital Copier
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
Xerox WorkCentre M15i Laser Printer Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
