Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
I have a Minn Kota Endura 30, transom mount. Just wondering, is there a way to rotate the controls so that I could use the motor on or near the bow of my 15' Aluminum fishing boat?
  • pandsphil Mar 12, 2009
    Remove bolt that holds control box to shaft. Turn unit 180 degrees, being careful not to
    pinch electric wires inside, then reinsert bolt and tighten nut.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
Posted on Apr 17, 2009
What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Trolling Motor specs
call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
Hi!
Here is a schematic for your motor:
Endura 30
It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
Best of luck!
Mike
Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
I need a truster speed for a Minn Kota Endura 46
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn kota endura 30 repair
The top section will pop off when the six screws are removed. It might just be dirty and sticking.
Apr 12, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
598 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
