Question about Refrigerators
Water leaks every few months around the water dispenser
  • 6,784 Answers
If the water is actually leaking from the dispenser hose, this will be the water valve that is not shutting all the way. you may need to replace the valve. it could have a faulty shut off seal.
Posted on Mar 10, 2009
  • 163 Answers
Make sure your ice dispenser chute is closed fully.water valve could be going bad but check lines to make sure everything is tight
  • 10,515 Answers
  • taran_2005
    taran_2005 Mar 10, 2009
    Mine one would be a video that would help you reasons and how to fix that .
  • Refrigerators Master
  • 13,433 Answers
Since your refrigerator Leaks I first suggest to have a look at this troubleshooting guide, see if its helpful.
http://www.repairclinic.com/0088_4_1.asp#Level1_5
Constant, slow leak from water dispenser on whirlpool refrigerator
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Jan 02, 2013 | Whirlpool Refrigerators
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Water intermittently leaks from dispenser for past few months.
Try unplugging the water control valve on the rear of refrigerator on the side that turns on the dispenser. If while unplugged you continue to get dripping water it would point to the dual water control valve being defective. Tell me what you find, Sea Breeze
Apr 18, 2010 | KitchenAid KSCS25FKSS Side by Side...
In the last 2-3 months I have purchased 2 of the Sunbeam Combo Water Dispensers and both of them overflow. After setting the bottle in the ''no spill receptacle'' after awhile they will overflow around the...
I would say that the dispenser is at fault. These water dispensers use gravity to release the water and won't allow overflow. The air pressure in the bottle comes up through the dispenser as water flows out. Your dispenser is not seating against the bottle correctly. Look inside at the gasket material that the top of the bottle rests on when it is in the inverted position. That's where the problem lies. The leak is happening right there where the bottle rests down in the reservoir. Look at that seal, it's damaged. Leaking...
Sep 22, 2009 | Kitchen Appliances - Others
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
