Question about Avaya 4412D Corded Phone
Need to change date on phone system to reflect correct time
Due to Eastern Standard Time
  • formulacoop May 11, 2010
    Are you needing to update the phone system time so the time diplay on all phones will be correct? If so it can be done at a 4424LD+ that has been setup as the programming phone. The only other way is to have a remote tech dial into the system and update the time. If you need assistence with this let me know. I am setup for remote capabilities.
    Mark
    formulacoop@yahoo.com
OR, you could go to the programming phone and program it yourself.
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Posted on Mar 11, 2009
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Thanks for all your help on ram chip now here is some thing no one has ans.
Which email service?
Do you have your profile set to reflect the time zone you're in? Unless you told it otherwise, the email service may have defaulted to its default time zone.
Hmmm, five hours. Are you by any chance in the Eastern time zone while the email service defaults to Greenwich?
Jan 12, 2015 | Computers & Internet
Set clock on the kendle fire
On the home page, tap the gear icon at the top. Tap "More...". Tap "Date & Time". Tap "Select Time Zone". Scroll if necessary and tap "Eastern Time GMT-5:00".
Dec 30, 2012 | Computers & Internet
My Asus Eee 1005 netback time, date are wrong when started. Thought it may be cemos battery. This was replaced. Still have problem. Help
Have you verified your time and date settings for your operating system? Please ensure that it is the correct GMT time.
Example, if you live in New York, your time and date should be set to Eastern Standard Time (GMT -5)
Mar 16, 2011 | Computers & Internet
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
How do I set my clock on my computer? It says that the time is 6:45PM when it is actually 9:36PM eastern stander time..
double click the clock/time in the system tray in the lower right of your computer screen, then click on the time zone tab and select the eastern standard time zone and tick off the box in the lower left of that box for the automatically adjust for daylight saving time, then select apply in the bottom then ok...now recheck your time..it should now read the correct time.
bill
Jul 16, 2010 | Dell Dimension 3100 PC Desktop
How to change time stamp on messages to reflect correct time. Time on phone system is correct
Dial into the voicemail and enter *#
followed by the System Administrator2.gif Mailbox number:
[#]+[0] = two-digit mailbox system
[#]+[00] = three-digit mailbox system
[#]+[000] = four-digit mailbox system
When requested, enter the System Administrator password. Default = [9]+[#]+[56].
Press [4] to set date and time
either enter:
[1] to review data - the current date and time settings in the Voice Mail are announced,
then you are returned to the Administrator Options Menu.
-or-
[2] to change data - after the first prompt, enter the time in four-digit military time format
e.g., 0930 for 9:30 a.m. or 1830 for 6:30 p.m. After the second prompt, enter the date as a
six-digit number in MMDDYY format. You are then returned to the prompt that asks if you
want to review data, change data, or exit.
Nov 13, 2009 | Vodavi Starplus DHS 7314 Executive Phone...
Norstar CallPilot 100: need to change the time within the system to reflect daylight savings time
the time change goes off the system time to change system time press feature **7463 enter the admin password then press change and enter new time
Mar 09, 2009 | NorStar CallPilot 100
Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Avaya 4412D Corded Phone Logo
143 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
