Schematic of the Xerox XC865
Does anyone have a schematic of the Xerox XC865? I replaced the broken fuser drive gear, but have a part that came off when I was replacing the gear and have no idea where it goes.
Thank you.
  • 628 Answers
Usually you can find the place to put the part by noticing the location of mounting holes or an obvious space on the fuser where it should go. Otherwise you might check with some of the places that sell replacement fuser assemblies. They might be able to send you an exploded view of the fuser.
Posted on Mar 10, 2009
We have XC865 the copier was working just fine until today. The paper keeps jamming inside. It would start to copy and then just gets stuck in the middle of the cycle. So I have to open the machine up...
Most likely a common problem of a broken fuser drive gear. This is especially true if the lead edge of the paper is stopping at the fuser assembly. This is the assembly that is hot to the touch. There is a upper fuser roller drive gear that breaks on these and causes the fuser roller to stop turning. So everytime the paper gets to the rollers it stops and a jam reults. The gear is 16.00 at precisionroller.com part number M510X
Here is a picture of the gear.
Sep 17, 2010 | Xerox Office Equipment & Supplies
My printer keeps jamming. I have replaced the
The most common cause for jamming every copy on this model is a broken fuser drive gear. If you open the right side door you have a gate that flips open with a bunch of "teeth" on it. This gate is part of the fusing unit. If the paper always stops in this area when entering the fuser it is a broken drive gear. Your Xerox is made by Sharp. The part number for the gear is NGERH0540FCZ3
Perhaps you can find a local repair person who can replace it for you.
Good Luck
Nov 24, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
Cracked fuser drive gear for Xerox copier XC865
There is a metal clip that holds it on the roller. Look in the machine for it.
Jan 31, 2009 | Xerox CopyCentre C123 Copier
Copier won't fire up
your fuser unit is not working .open and see your thermofuse, thermistor or your heater lamp is out. if there is dirty between your thermostart & your fuser roller, clean . check for continiuty on your thermofuse & fuser lamp. thanks
Nov 12, 2008 | Office Equipment & Supplies
How can I replace the fuser on xerox xc865
it is pretty easy. You have to remove the lower front cover, located just above the paper tray, 2 screws to remove and pull forward.
Then there is one screw in the front of the fuser, It is a shoulder screw. Once that screw is removed you push the upper fuser toward the back of the machine slightly. It will pop off a locating pin. There are 2 plugs to disconnect and the fuser will come out once those are unplugged. The pressure and pressure cleaning roll just pop out of the frame once the upper fuser is removed.
Not hard at all.
Sep 07, 2008 | Xerox Office Equipment & Supplies
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
123 people viewed this question
jasbo
jasbo
