Question about Toshiba e-Studio 350 Copier
Mycopies come out with2 black streaks and it is
My copies come out with 2 black streaks and it is not from the glass. It must be on a roller from a misfeed
  • Anonymous May 11, 2010
    how does a printed page look?
  • 2,072 Answers
Have you tried pulling the green or blue handle one the front of the machine in and out about 10 times? That cleans the charger and can often resolve that issue.
Posted on Mar 11, 2009
Black streaks on both side of paper when copy on glass
Throwing the machine away is the best recommendation. You have a bad drum/developer that is leaking some toner. Could be a bad cleaner blade for streaks on the front; fallen toner for streaks on the back. Careful cleaning, replace transfer roller. First, check the condition of the fuser assembly. If the soft roller is bad it will leave toner buildup on the teflon roller, and vice-versa. Start there.
Sep 03, 2014 | Copystar Office Equipment & Supplies
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Black Streaks on copy
This means that teflon is wearing off of the Fuser Roller. It collects toner and then tracks it back on everu copy. It needs to be changed out by a trained tech.
The other thing that can cause this is a bad drum. Both about $200 I believe.
Dec 29, 2009 | Sharp Office Equipment & Supplies
Black vertical lines in copies
You need to clean the glass. Open up the feeder and you have a large piece of glass for scanning and to the left a smaller piece of glass that it uses to scan from the feeder. Clean this smaller piece of glass; even the slightest smudge can leave a black streak.
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
May 11, 2009 | Sharp Office Equipment & Supplies
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Black streaks on paper
Most leasing companies will not provide financing unless you have a maintenance agreement by an authorized servicing agent. These parts should be covered under that agreement. If I can help, contact me at
Apr 10, 2009 | Panasonic Workio DP-2330 Printer
Black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Mar 11, 2009 | Gestetner DSc224 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Black streaks across the page
hello,first of all,make a copy true the adf,and the next on the platen glass,if both copys are good,then the problem is inside the machine,i.e.drum unit or fuser roller damage.
if the strikes only occurs,by using the adf,then cleaning the scanner platen glass,it is the small glass unit!!! on the left side,from the big platen glass..
good luck Sjeuf
Apr 11, 2008 | Panasonic Workio DP-2330 Printer
Toshiba e-Studio 350 Copier Logo
103 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
