Question about RIM BlackBerry 8820 Smartphone
Ear speaker and voice microphone do not work.
The speaker on the top and the microphone on the bottom do not work. When I plug in a headset to the side of the phone it works just fine.
    Scholar:
  • 132 Answers
Probably hardware related. Did you recently download anything to it? Try resetting the hand held unit.
Posted on Mar 30, 2009
How do i fix my iPhone so the receiver can here me when i talk
1.Unplug anything plugged into the headset jack.
2.If you're on a call and holding your phone next to your ear, speak into the microphone and make sure you don't block it with your fingers or shoulder.
3.If you're using a screen protector or case that covers the microphone, remove it. Clear any debris from the microphones.
4.Restart your device.
5.Update to the latest version of iOS.
Test the microphone
To find out if there is an issue with the microphone itself-and not the app you're using or your cellular connection-test the microphone with the built-in Voice Memos app. Speak into the microphone and then play back the recording. You should be able to hear your voice clearly.
*If you can't hear your own voice the microphone is not working properly, you should replace the piece of hardware.
Jan 27, 2015 | Apple iPhone 4 Black Smartphone
I want to attatch my mic to my motherboard
desktop or laptop computer ?
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
Sep 19, 2012 | Biostar P4M900M7FE Motherboard - VIA...
I can hear the voice from them but they can not hear the voice from me
when everyone can hear your voice while you can hear their voice during making a call, it seems the problem is in your microphone, it means you have to oven the phone cover at all, find the microphone that use to located in thr bottom of the motherboard, try to clean the circuit of the microphone, or replace with a new microphone..for a while you can use a headset or nokia earphone that similar with your model.
hope it will help.
May 14, 2011 | Nokia 6030 Cellular Phone
No sound in yahoo messenger
Here's how to troubleshoot microphone and speaker problems:
1. Click the Messenger menu and select Preferences. The Yahoo! Preferences window will open.
2. Under Category on the left, click Voice & Calls. in version 9 or Video & Voice in version 10.
3. Check the microphone and speaker settings:
- For Yahoo! Messenger 9.0, test your selected speaker by clicking the little Play arrow beside it. Then test your selected microphone by speaking into it, if it's working you'll see an animated level indicator.
- For Yahoo! Messenger 10, test your microphone and speakers by clicking the Open Video and Voice Setup link.
4. Check your system volume by clicking the Speaker icon in the Notification Area of your Windows Taskbar, located at the bottom-right corner of your screen.
- Drag the Volume bar to the top.
Remember: If the little speaker icon below that volume slider has a red circle with a slash through it (no symbol), your sound is muted. Click that speaker once to turn off muting.
- Next, if that didn't work, go to the Mixer, located below the volume bar or access it by double-clicking the Speaker icon in the Taskbar. Make sure that none of the options has been set to mute, and that all levels are set to above 50%.
Your microphone and speakers should now be functioning properly.
Here are some additional things to consider:
- If you're using a headset, make sure that the jacks are plugged in to the correct connectors on your computer and that you haven't accidentally selected a mute switch.
- If you're using a USB headset, make sure your USB connection is functioning properly. Try using another USB device in that connection to test to see if it works.
For more help regarding yahoo messenger, visit
http://help.yahoo.com/kb/index?page=product&y=PROD_MSNG_MSNG10
Sep 05, 2010 | Yahoo Messenger
2600: speaker is ok but no sound in nokia2600...
Change your earpiece.Need to know in phone have 3 kind of mic:1,microphone to make somebody hear our voice. 2.Ear piece to make we can hear for sombody voice. 3..Buzer to make phone ringing or louder sound when somebody speak (speaker). in that case your earpiece is not work,so change your ear pice. I hope it help.
May 17, 2010 | Nokia 2600
Computer wont recognize the microphone on the turtle beach x4
Can you try using the X1 mic on your PC? Green plug to green jack, pink plug to pink jack, USB plug to USB port. Talk into the X1 mic. Can you hear your voice? If yes, then you probably have a bad chat-controller cable. If no, then your X1 mic may not be working. If that's the problem, you should contact Turtle Beach tech support for help. support@turtlebeach.com.
Jul 21, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
How do I connect a mike headset to a Dell Dimension 3000?
Does your headset have two plugs? One will plug into the mic jack that would be your Microphone. The ear part plugs into your sound out or speaker out.
Jul 11, 2009 | Dell Dimension 3000 PC Desktop
Headset earpeice :)
make sure that voice sound is set to come through ur headset and not ur tv speakers.
Jan 01, 2009 | Microsoft Xbox 360 Console
Logitech headset, new vista operating system
either the headset is not supported by Vista, or you need to right click on both speaker icons, normally coloured red and black and in the properties you need to see if your headset is listed as one of the microphone input devices, if you need to make the Logitech headset the default mic and not the windows generic mic. If you do not see it in the properties then it may not be recognised by Vista.
Aug 13, 2007 | Logitech Internet Chat Consumer Headset
Problems with speakers and microphone on 6515
try plugging the ear bud into the bottom an unplugging it again it worked for me.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
RIM BlackBerry 8820 Smartphone Logo
378 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
