Question about Tools & Hardware - Others
Need a repair shop to change internal drive belt i just burned up my third one... small porter belt sander
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number and where are you located I will try and help
  • 32 Answers
You do not need a shop as they would do no more than you have and you would keep burning up belts. The reason for belts burning up is the bearings, when they heat up the old grease in them thickens up it binds them up. Replacing them is not cost efective, unless you have the time and knowledge to get to the bearings and work a light machine oil into them without getting any oil on other electrical componants as it will burn the electrial windings, brushes etc. Hope this has helped.
Posted on Jul 18, 2009
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
How do I adjust the porter cable sander so that the belt runs stright?
The porter cable belt sanders have an adjustment knob (threaded screw with a black plastic t-nut on the end). The knob adjusts the angle of one of the rollers and thus the tracking of the belt. The know takes very little adjustment to change the belt's tracking.
Is the know perhaps missing? You can get replacement parts for for porter cable tools at www.servicenet.com.
Hope this helps.
Apr 27, 2011 | Porter Cable Garden
I have a Porter Cable 503 belt sander that heats up to the point that I can't touch it and have to stop using it to let it cool. I have been using this model for years, have relied on it exclusively, and...
I have a black and decker BR300 that I've had the same problem with.I don't know if yours is caused by the same things but what I found was that the vacumn system on mine was not sealed up good enough and too much dust was getting around motor cooling fins. Unfortunatly on mine by the time I figured this out it had frayed the drive belt which caused some small strands to wrap around drive gears and mostly trashed the motor. Hope this is of some help to you. Thanks
Nov 03, 2010 | Porter Cable Tools & Hardware - Others
I have a Porter Cable Model 371 2.5" X 14" Belt Sander. I broke a belt, when I did it jammed and also broke a rubber sleeve that covers the Drive Wheel. I have yet to find this rubber sleeve in any part...
Unfortunatly that sleeve is not available, you will need to purchase a whole new drive wheel. The Drive wheel is $9.66 from DeWalt Service Net. Porter Cable, Delta & DeWalt are all owned by Stanley Black & Decker, you can contact DeWalt Factory Service for all parts. 1-800-4-DeWalt You can order the parts on-line, over the phone or though a local service center. The website is www.dewaltservicenet.com Below is the parts diagram for your sander. The part number for the drive wheel is A16439
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65594&typeId=15450&documentId=34604
Oct 10, 2010 | Porter Cable 371K Factory Reconditioned...
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I have a Porter Cable 352VS Type 4 sander needs bearings.
You need special pullers for these, you will have to take it to a power tool repair shop.
Jan 26, 2010 | Porter Cable 3" x 21" Electronic Variable...
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
76 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
