Question about HP Pavilion 524w (DB280AR#ABA) PC Desktop
I have a hp pavilion mx75 with windstream
I have a hp pavilion 524w computer with windstream broadband internet service.It takes the computer forever to boot up and shut down plus using it is very slow. It seems to sit and grind away when I try to connect. My son moved back in with us for a while and I know that he used a lot of programs that I don't need or want. How can I clear some of this mess off without getting rid of something really important?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
Try this:
- Click on Start and select run
- Type in msconfig and click ok
- Click on Start up
- And you may uncheck the unnecessary programs
- and Apply it.
Posted on Mar 10, 2009
Hp 524w will not power on cpu
Replace the Power supply, or the Power switch.
Oct 07, 2013 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
I have the hp pavilion 524w desktop computer and I was wanting to know if it is possible to insert a newer version of the processor. 1.73 ghz is not fast enough. Is there anything faster that will go with...
The compatibility isn't with the memory, it's with the motherboard and its chipset. In your case the motherboard is a FIC AM-37 which has an VIA KM266A chipset - an extremely old chipset . The only processors accepted are AMD Athlon XP of the first generation of which you already have the fastest version
http://en.wikipedia.org/wiki/AMD_Athlon(tm)_XP_3200%2B#Athlon_XP_.22Palomino.22_.28Model_6.2C_180_nm.29
So no, it's not possible to upgrade it. You will have to buy another motherboard-processor combo.
Aug 04, 2011 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
How to fix start switch on hp mx75
It shows that the switch of your monitor is malfunctioning, it is having partial contact, that is why it works atimes.
I advice you replace the switch so as to get maximum effective use of your monitor.
Take care
Apr 29, 2010 | HP Pavilion MX75 17" CRT Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
How to get motherboard out of a hp pavilion 524w
On the outside, disconnect the power-cable, then the keyboard/mouse/video/audio/USB/printer cables.
Disconnect all the cables from the power-supply to the devices (disk, CD-ROM) and to the motherboard.
On the outside-back, remove the screws holding the power-supply in position, and then remove the power-supply.
Remove the screw holding each add-in card (audio, video, modem).
Remove each of the add-in card(s).
Remove the ribbon-cables from the motherboard to the diskette & disk-drive & CD-ROM.
Look for screws holding the motherboard to the case.
Remove those screws, and gently lift out the motherboard.
Oct 31, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
How to remove dvd player from hp 524 pavilion
remove both side panels by unscrewing them at the back then remove the screws holding in the drive and unplug the drive.
Oct 07, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
I recently moved and when I hooked up my computer, the tower will not power on. What could be causing this
There is a master power switch switch on the back of some computers, just under where the power cable plugs in.
Jun 28, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Can you tell me where USB port is located in HP pavilion MX75
USB ports are located on the back and also on the front on newer desktop PCs. These are on the computer tower - not the monitor as your posting is categorized. They are rectangular slots with four copper contacts inside.
Jan 30, 2009 | HP Pavilion MX75 17" CRT Monitor
Cannot connect to internet
There could be many types of connecting to the Internet. Here are some types of Internet that you can connect to.
* Dial Up Connection
*Wireless Router or Access Point.
*Broadband
*Wireless (Recommend for Laptops)
*Ethernet (Recommend for Computer)
To connect to the Internet, try contacting your ISP (Internet Service Provider). If you haven't one so, then contact a Computer Technical Service.
Thank You for Using FixYa!
Oct 19, 2008 | HP Pavilion dv2000t Notebook
Pavilion MX75 monitor clicking.
What has happened is the automatic screen size & resolution detection circuitry is going/gone faulty. You usually hear this sound ONLY when ya change screen resolutions, ie: when say ya change from 800x600 to 1024x768 or the like. With 2nd monitors so inexpensive these days repair is often NOT warranted.. so perhaps it is time to upgrade to another. However if ya choose to have it repaired obtain a "Quote" and an explanation B4 ya proceed.
Aug 09, 2007 | HP Pavilion MX75 17" CRT Monitor
HP Pavilion 524w (DB280AR#ABA) PC Desktop Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
