Whenever i try to asscess gprs on my n72 handset through default browser it shows PACKET DATA CONNECTION NOT AVAILABLE, CHECK NETWORK SETTINGS....and when i try it by opera browser it shows JAVA I.O.I.8..EXECUTION ERROR....something like that....i format my cell many times by *#7370# method but problem is not solved.....help me
Dear Mikunj
First of all the error u have said is occur due if there is no proper setting or packet data not available
So first subscribe packet data from your service provider they will send you gprs setting via message,save it then long press 0 key to start gprs (wap) page
Now most of service provider gives free surfing to gprs,so check it with customer care
but if you have already have subscribed packet data & have gprs setting in ur phone & still problem occurs then ur phone's certificates has been corrupted & u have to reinstall it
Thanks
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
Manual setting GPRS on Nokia E71:
1.
Seeks Nokia Menu > Tools >
Settings > Connection
2. Select Access Points > Options > New
access point > default settings
3. Name the connection
4. Set Data bearer to Packet data
5. Fill in access point name (APN)
6. Set Username (None)
7. Set Prompt password to No
8. Set Password (blank)
9. Set Authentication to Normal
10. Set Homepage to whatever site you like
11. Back #2
12. Select Packet data
13. Set Packet data connection when available
14. Leave Access point blank or
Depending on your service provider settings, You may need to get their default setting on some items listed above.
i can not connect to the internet.when i try to connect with internet i have problem in my packet data connection .packet data connection is not available .plz give me the advise.
