Question about Maytag Performa PAV2200
My Performa dryer stopped working.
We dryed a load of clothes last night, and then this morning nothing. We put a load in the dryer, and nothing. There is power getting to the dryer, and the door latch is secure. Nothing is working. We are in the military and have been at our current duty assignment for approximately 1 year, and the dryer has worked great until today.
  • Farley Redfield
    Farley Redfield May 11, 2010
    the fellow IN FRONT OF ME MAY BE RIGHT BUT from WHAT i BELIEVE YOUR SAYING IS 1-its 220v electric dryer? sorry about the cap lock was on ; 2 -you have power - which means either you have 1 line of 220 v comming in or both lines.
    If you check power to ground it will mislead you. check across line L1 to L2 and L1 - N and L2 - N then if you have a goound L1 - Ground and L2 to ground and post me the readings, you should read (if your in USA) L1 - L2 220 = 245Vac; L1 -N & L2 - N 110 - !28V And L1 & L2 to Ground 110 to 128V Any readings beyond these and you need to reset the breaker even if 1 is reading correctly turn it off and back on then retry it.
    If it was the thermal link like the fellow said above it would do more than just protect the heating circut and it may indeed have one for that reason. Check power to the cord connection after checking the wall outlet. If you have power to this point He may well be correct.
  • Maytag Master
  • 3,361 Answers
Unplug the dryer.
Replace the thermal fuse and high limit switch located at the heater element.
The parts come as a set.
Raise the top lid of the dryer. The parts are at the back left side.
Posted on Mar 10, 2009
Frigidaire dryer won't run--starts then stops
please tell me how much load you are putting in it
Apr 12, 2018 | Frigidaire Dryers
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer is not heating and will not stop running
if you were running it on timed cycle and it was still running with no heat then you have a bad timer and if you were running it on auto cycle and it was still running and its electric dryer then you have a bad element ,,, if its gas you may have a bad ignitor / larry
Dec 04, 2008 | Dryers
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
Maytag performa dryer
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Washing Machines Logo
303 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
