Question about Symbol MC9090 Barcode Scanner
I get a "Connection Rejected" error when I try to connect the scanner to a PC
    Novelist:
  • 75 Answers
This could be a number of reasons.
First check that there is no password set on the hand held device.
Go to Control Panel >> Password to delete.
You may also have to many Partnerships on the host PC. On host PC open up ActiveSync and then open File and Delete Mobile Device.
If that all fails try re-installing Activesync and the host PC.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 15, 2009
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
Scanner won't work with compaq cq58
You orobably do not have the required drivers for the scanner. I suggest you to browse the manufacturer's website and download and install the latest updates from there. Also if they recommend any utitlity along with driver intall it and then try to scan the document. This will hopefully resolve the issue.
Sep 19, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Google Chrome's connection attempt to www.facebook.com was rejected. The website may be down, or your network may not be properly configured.
Such type of problems mostly occurs due to slow internet connection. I would suggest you to optimize internet. Also try to update the drivers that control your PC and scan your PC with an updated Anti-Virus.
I would suggest to use PC optimizer tool like PCfresher that will not only fix windows internal errors but will also optimize internet.
Feb 11, 2013 | Google Chrome
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Facebook page did not load. error: connection request rejected by server. tried various browsers for login ... no luck. pls help
It seems, error messages occur when there is a problem with the Web site that you are visiting. The problem may be temporary.
Please try after sometime.
Sincerely Thanks
Aug 30, 2011 | Facebook Social Network
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
When I try to open the Scanner software the following comes up... Error = 4 Could not confirm scanner connection.Please check scanner connection. When I try to open the easyscan Utility I get the following...
Minolta's crummy software is notorious for this. Most people can't get it to work even by removing and reinstalling the driver software. The best solution is to use a third-party driver software called VueScan. You can download a trial version for free to see if it works before you commit to buying it. If this doesn't solve it, you most likely have some sort of hardware problem.
http://www.hamrick.com
Jul 19, 2009 | Minolta Dimage Scan Elite 5400 Film...
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
Error code 08
Unplug your scanner and switch off your PC. Check the USB connection is secure on scanner and pc. Wait for at least one minute, then switch both back on. Your display should go back to 01 now.
Sep 04, 2008 | HP ScanJet 7650 Flatbed Scanner
Symbol MC9090 Barcode Scanner Logo
240 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
