Question about Dryers
Change the heating element on a Kenmore 90 series dryer, no heat, could the problem be the thermal fuse
  • 2 more comments
  • hamneggs1081 Mar 10, 2009
    okay, tried taping the plugs together, still no heat, any other ideas?
    I don't have access to a meter. None of the circuits have been tripped. Anything else before I push it over a cliff?
    One more question, the dryer should heat up quickly, correct? Meaning that as soon as it is turned on, i should feel heat.
    Mildcooksey, thanks for your input. I am going to eat some lunch, then get back to it, again thanks for your help!
  • 163 Answers
Yes,i would check with a set of meters to see if it has continuity.it is located at top of element cage.or a tip you can check it by taking the 2 wires from the thermal fuse and pu them together with electrical tape plug the dryer in and see if it heats.
Posted on Mar 10, 2009
  • 1 more comment
  • mike cooksey Mar 10, 2009
    check breaker and if you have meter see if you are getting 220 to the dryer,they will run on 110 but not heat.
    could be in timer or motor switch but cant check without meters.sorry
    you should feel it heat within a few seconds,let run for about 5 to 10 seconds and it should heat by then.
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
I have a Kenmore 90 series dryer, drum turns but will not heat up.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 25, 2011 | Kenmore Dryers
Kenmore dryer 90 Series is not heating.
This sounds like it could be the thermal fuse or the heating element. You can check the thermal fuse and heating element for continuity with an ohm meter. No continuity would be bad. The fuse is usually located close to the duct. Hope this helps.
Jul 16, 2009 | Kenmore Dryers
We have a kenmore dryer model 11068934792 ser. mj3303110 -90 plus series we do not get any heat when it is running
It sounds like you have a bad heating element or thermal fuse. The fuse cannot be reset. If it is bad, then it will need replaced. Often a dryer heating element burns out, but doesn't triop the circuit breaker or blow a fuse. The heating element is simply a long coil of wire. You can check it for continuity with an ohm meter. No continuity means that the element is bad and you will have to replace it. The elements are not repairable. Hope this helped.
Jul 16, 2009 | Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Dryers Logo
171 people viewed this question
Top Dryers Experts
