My computer stopped reconizing my primary and secondary channels. I stripped down my computer completly including removing my CPU. I put it all back together and now it won't boothup nor will my minintor show a screen or stay on longer than 2 seconds. I'm running Windows XP.
hi, is the ide-ata enabled in the bios? do you have sata? and is it enabled?also did you put thermal compound on the cpu' s heatsink when you put it back on the cpu? the 2 second on thing sounds like over-heating,do check the bios first. alot of motherboards have a thermal shutdown, so if the fan or compound failed, it would quikly shut off. as for the channels not working-you can try your primary drive, and see if it boots. but first see if it is on in the bios. check and replace the battery on the motherboard. post again if you need help good luck! hope this is helpful.
We have a model G20-101-001 MegatouchXL Touchscreen. When we turn it on it goes to a screen which...
(More)
We have a model G20-101-001 MegatouchXL Touchscreen. When we turn it on it goes to a screen which tells us that there IT SAYS Boot disk failure, Insert Disc and press enter. When we do this it goes to a screen where you can enable and disable but we are unable to get to a regular touch screen???? What is your advice
my optional components in my registry editor have no value and is causing a interruption on the...
(More)
my optional components in my registry editor have no value and is causing a interruption on the download of adobe reader.
I was just trying to understand the different processors that toshiba offers. Especially which are...
(More)
I was just trying to understand the different processors that toshiba offers. Especially which are 64 bit and 32 bit?
