Question about Proscan 26LB30QD 26 in. LCD HDTV
How do you change the keypad on a proscan 26lb30q? The channel up button does not work. the part can be purchased for low cost, but how difficult is it to change?
  • Anonymous May 21, 2009
    the problem is with the keypad on the side of the tv, not the remote
    President:
  • 814 Answers
Tools needed for the repair. 1 small screw driver and 1 small plastic pry bar. you may also need the use of a small solering iron to seperate the power supply wiring from the main board assembly. There are usually small screws in the back of the unit that must be removed first. When all the screws are taken out you must use a small plastic pry bar to separate the top and bottom sections of the remote. This will usually expose the electronic switch pad that is used to do all the interaction with the electronic controls of the remote.Below these keypads are the actual switches that perform the function. This is usually a small circuit board with a small battery operated power supply on a main circuit board. This is the board that will be having the problem with the control. You should test it first to make sure the malfunction is not some mechanical problem between the switch cover and the switches. Also check the switch to make sure the point of contact is clean and clear .IF this is all working fine. Then you need to replace the unit. The switch is probably damaged internally and cannot be repaired. Replace the switchboard with the new one and reconnecting to the battery power supply. Putting the unit back together by reinserting all the screws.You should now have a functioning remote control. I hope this has helped you with your problem.
Posted on May 21, 2009
Proscan PLEDV 1945A-B will not recognize cable. Auto channel scan results in no channels found
Do you have the converter box to convert the incoming signal from digital to analog, you must have this to receive broadcasts.
Nov 04, 2016 | Proscan Televison & Video
I need to download the user manual for the product described below.
looks llike you may have to pay for it. see link below
Jun 05, 2015 | Proscan Televison & Video
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
What remote do I buy for the Proscan LCD 26lb30q?
Try Ebay they have them the item number is 350167917823 just type that in the top where you would put in what you want to find.
Feb 25, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
The screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Channel changing on PROSCAN 32LA25Q
I had the same problem, what fixed it for me was to set auto scan to setup all the channels for me again. Another thing to check would be whether it is set up to use CATV or AIR.
Dec 26, 2007 | Televison & Video
Proscan 26LB30QD 26 in. LCD HDTV Logo
79 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
