Armstrong 4PHP13E36P runs after heating element cools
I need to know where to adjust the length of time that an Armstrong 4PHP13E36P-1A blower runs after the heating element shuts off. The unit blows cold air into the house after the heat stops, which cools the house, causing the thermostat to start the whole cycle again. This is clearly wasting energy and wearing out our unit prematurely.
  • peyton thompson
    peyton thompson May 11, 2010
    the time is preset on the fan relay if the fan is not shutting off after 1-2 minutes then the fan relay is bad and needs to be replaced.
    Scholar:
  • 144 Answers
There may be pins on the circuit board inside the air handler that you can adjust. First turn off the breaker then look inside at the board. They may say 30-45-60-90 etc. Put the pin on a lower number. Do you have a digital or programmable T-stat? There may be a setting in the T-stat setup program that allows for blower delay also. consult you installation instructions. Last if the blower isn't turning off at all then the relay on the circuit board is stuck closed and should be replaced.
Posted on Mar 10, 2009
My fan is not turning on my armstrong model 2php13e48p-1a. How hard is it to replace?
without a meter a knowledge on how to test I would replace the $10 capacitor first. keep in mind that just because the fan isn't running doesn't mean the motor is bad.
Feb 11, 2018 | Heating & Cooling
Blower on a comfort glow heater
Most of those switched is non adjustable but some are .if that's where the switch was all along and everything was working then I don't think it's the switch location .
Check to see if you miswired or got loose connection .
Dec 12, 2017 | Comfort Glow Heating & Cooling
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
When thermostat turned up furnace ignites, heats and fan starts when plenum is up to temp. When thermostat is turned down flame goes off but fan continues to run.
If your furnace is relatively new, as in 10 years old or less, there should be a field adjustable 'cool down' cycle. On the circuit board there should be a dip switch or series of dip switches with 30, 60,90,120 indications. These numbers represent the length of time the relay on the circuit board allows the fan to run AFTER the thermostat satisfies. You may be able to adjust the time frame down one position from where its positioned now.
The second possibility, if the blower never shuts off at all is that the relay itself could be stuck in the closed position and keeping the fan on.
Sep 30, 2015 | Heating & Cooling
Why won't it start?
It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
Sep 24, 2015 | Heating & Cooling
Why won't it start?
I copied and pasted this answer from your other question as I thought it was the same one Sherry.... Hope it helps you.
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
I have a charmglo electric fireplace blower works but there is no heat is it the thermal cutoff and if it is what do I replace it with and also can it be put in backwards
More than likely it's the Thermal overload circuit or the heating element has given up the ghost.
As I just told one other questioner. These types of electric fireplace heaters were not designed to run for long periods of time. Their heat output is not much more than a blow drier. However, this is not just a problem with CharmGlo, it's with all the manufacturers.
Here's the problem ... The heaters work by taking in cool air, heating it and sending it back out via the blower. Over time, the heating element and/or blower become clogged with dust, lint and/or pet hair. This makes the heating element work harder and it over heats. Either burning out the heating element or the thermal overload switch or both.
You can try cleaning the heating element with a vacuum that has a hose and a brush attachment. While you're at it clean the blower fins and motor. Consult your Owners Manual to see how to access these parts, as they are under firebox, behind the metal grill on the bottom of the firebox, so to speak.
Feb 05, 2011 | Heating & Cooling
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
