Question about Nintendo DS Console
Charge light orang on for a second and turn off unit not charged.
My son has Nintendo ds original style Model No.NTR-001. when he connect AC charger to unit the charge light (left one) come on orance and turn off immediately unit not get charged. but when he turn on the unit with the AC charger the unit is working normally. can you tell me what is the problem with the unit.
Thanks for your help.
Rakesh.
  • 275 Answers
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Posted on Mar 10, 2009
My ds model ntr.001 will not charge or turn on
It sounds like the battery has gone bad- (I've tried running the DS w/ power only, it does not work- it HAS to have the battery engaged.)
You can find replacement components all over the web, bar that a stop to a local game store can pick you up an used DS for about 60.
Jun 13, 2011 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo ds not charging
. go to ebay or even gamestop and purchase a new battery. sounds like the battery might have gave up. these kind of things happen, rare but happen
oither things it could be is a cold solder. the female power jack might not be fully soldered on the board. causing the battery not to be able to charge.
i think if you change the battery it will work. make sure you get the correct model/brand u dont want no knock off batterys
May 20, 2008 | Nintendo DS Lite Console
DS not turning on or charging
it could be a stuffed charger or power supply problem sometimes when you drop it that does it i suggest you buy a new one or send the old one in to nintendo if u can trick them into ur ds bein almost new...
Jan 12, 2008 | Nintendo DS Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
DS charger
get a new battrey or google it ,go to nintendo.com , or u might have to get a new one
Oct 16, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
293 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
