Question about Whirlpool GU2400XTP Built-in Dishwasher
Looking to wire my kemore elete dishwasher to a power source
    Novelist:
  • 108 Answers
Is there no power source where you are installing it?
Posted on Mar 10, 2009
Power failure light is being displayed on my dishwasher
I appreciate your inquiry, Bernadette Beharry!
From the information you have provided your Frigidaire dishwasher is displaying a power failure on the control panel. This could be a possible problem with your power source, control panel, or wiring issue. I understand that you have reviewed your power outlet. You may need to perform a reset on your dishwasher and to do that you can flip your household circuit breaker in the off position for roughly ten minutes. If the power source is fine and the reset does not correct the issue you may need to have a professional come out and repair your dishwasher. This will help to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Feb 15, 2015 | Frigidaire Dishwashers
Kemore Dishwasher Model 15958792 -no power showing on display.
Daniel, I think you may have to get a trained Service man to look at it. I presume the 'fuse' you refer to is inside the machine? If so, it should only be touched by a qualified and trained person. You could possibly risk being electrocuted, and losing any Warranty.
Oct 29, 2017 | Kenmore Dishwashers
Keeps flashing pf while not on. try to run and it starts and stops after a short wash. have to reset to empty the dishwasher.
Flashing PF = power failure. The power source and connections need to be inspected for bening loose or hot. This would be at the wall connection and in the bottom of the dishwasher. If the supply power source is good all the way to the dishwaher and to the dishwasher control.. suspect corrosion in the control area as the source of the problem. When corrosion gets on an electronic board it starts acting like a conductor for the low voltages produced by the PDB transformer which starts causing all kinds of weird symptoms. If the PCB can be cleaned carefully you can maybe get 6 months to a year out of a PCB that has / had corrosion problems. My 40 years experience is that only one in 5 can be salvaged back into service. Additionally those that are placed bacm in service eventually have other problems.
If you have a loose plug, wires, outlet or power cord... your in luck.
Thanks for choosing FixYa,
Kelly
May 29, 2011 | Dishwashers
My kemore nautilus had been fine but now will not turn on
make sure to check for power. these have a fuse behind the panel
Feb 05, 2010 | Kenmore 24 in. 16992 Built-in Dishwasher
Kemore dishwasher 665.17029403 is hooked up, breaker not tripped but no power at all - lights will not come on. Power initially would be intermitent - lights on, then off, but now there is none. Is the...
I would check the power conction under the dishwasher. Make sure the power cord is disconected or the breaker that supplys power to the unit is off. remove the kick plate at the bottom of the machine and locate the power concetion box and inspect the wire nuts.
Jan 07, 2010 | Dishwashers
Where do you find the model # on a Kenmore Elete?
You should find a label on the inside of the dishwasher (left side) that provides model information.
Jul 25, 2009 | Kenmore Dishwashers
Kenmore elete dishwasher flashing light clean
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Sep 08, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
