My eMac will not turn on. I had it in the "sleep mode" and there was a short power outage in the Los Angeles area. Later when I came to my Mac, I couldn't get it to turn on. Is there a fuse that's replaceable or a reset button that should be pressed? Please help. Thanks, Reggie
    Brigadier General:
  • 8,619 Answers
Hi!
There is a power supply failure, please check the power supply--
  • Step 1: Plug the PC into an electrical outlet rather than relying on a battery to power up the system.
  • Step 2: Eliminate a faulty electrical cord as the culprit. Examine the cord that runs from the PC to the wall outlet. Determine whether there are any indicator lights within the cord itself to identify functionality. If there is such a light and it is not lit when plugged in, the problem may be with the cord and not the PC.
  • Step 3: Try to turn the PC on. To diagnose the internal power supply as the culprit, it is essential that there be no sound or monitor activity whatsoever. The PC needs to be completely dead.
  • Step 4: Unplug the PC.
  • Step 5: Open the PC.
  • Step 6: Identify the power supply. It will be a metal box containing a power cord receptacle (where you plug in the PC's power cord) and a small fan. It is usually located in a corner of a desktop PC.
  • Step 7: Remove the power supply plug from the motherboard.
  • Step 8: Insert a paperclip into the terminals (usually colored black and green) of the power supply plug.
  • Step 9: Plug the PC directly into a wall outlet. Do not use an extension cord.
  • Step 10: Press the power button on the computer.
  • Step 11: Examine the PC fan inside the power supply to see if it is spinning. If it is not, then you have diagnosed a failed power supply.
  • If, after you remove the power supply plug from the mother board, insert a paperclip into the plug's terminals and press the power button, the fan inside the power supply does spin, the problem is a failed motherboard rather than a failed power supply.
Posted on Mar 10, 2009
    Sergeant:
  • 300 Answers
The eMac's power supply is NOT auto-switching. The popping sound you heard was the power supply blowing out. Hopefully it will turn out to be just the internal fuse that's part of the power supply, and not the power supply itself, let alone the logic board. Just how bad the damage is would depend, I suppose, on just how fast that particular 'fast-acting' fuse actually is the problem.
If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU or PRAM.
    • For a portable (iBook or PowerBook), click here for instructions.
    • For a Mac mini, click here.
    • For an iMac, click here.
    • For a Power Mac, click here.
    • For a Mac Pro click here.
    • For a MacBook or MacBook Pro, click here.
    • For any other computer, click here for instructions on resetting the PRAM.
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
  • 10,515 Answers
Try resetting the SMU (system management unit) it specifically addresses startup problems with the iMac G5:
http://docs.info.apple.com/article.html?artnum=301733
if that would work its fine, unless
get a replacement for power supply . It would cost you around $115.
    Sergeant:
    Novelist:
  • 277 Answers
Check the power cord wire.
  • 13,433 Answers
Unplug your mac for 5 minutes, also disconnect the battery if this is a laptop mode. After 5 minutes plug it back in and try turning it on.
Where in Los Angeles County can I find a repair shop for screen under the glass. Bott half pixels are not coming in. Only can see half of the picture
  • In/Home Television Service inhometelevisionservice.com In/Home Television Service has been a ... tv repair professionals in Los Angeles ... office in Los Angeles County. What sets our television repair ...
  • Los Angeles County TV Repair ' Television Repair Service ... www.tvrepairman.com/ca/los-angeles-county Results for Los Angeles County TV Repair Service. ... Polaroid TV Repair, RCA TV Repair, Samsung TV Repair, Sanyo TV Repair, Sharp TV Repair, Sony TV Repair, ...
  • Orange County - Los Angeles TV Repair and Installation www.videotechco.com Videotech Co. is a Los Angeles County and Orange County California (CA) TV Installation company. Our services include: Home Theater Installation Services, TV repair ...
  • Dec 16, 2015 | Televison & Video
    Were can i take my rowenta steamer for repair in the 90035 los angeles area
    Anaheim, Berkley, Fresno, Bakersfield, Los Angeles,
    Long Beach, Sacramento, San Diego, San Jose and San Francisco.
    Google Rowenta repair Center, choose a city and go!
    Jul 24, 2014 | Rowenta Commercial Garment Steamer - White
    What city or town is this 213 area code located in?
    North American area code 213 is a California telephone area code which was one of California's original three area codes created in October 1947. It has historically been associated with Southern California and Los Angeles.
    Originally, it stretched from the southern portion of the Central Valley to the Mexican border. Due to California's burgeoning population, however, it has been subdivided numerous times. It now contains only downtown Los Angeles and its immediate environs, and is completely surrounded by area code 323. The subdivisions to date have been:
    Mar 29, 2011 | Computers & Internet
    Where can i get my mixer repaired in los angeles area ?
    1220 North Las Palmas Avenue, Los Angeles - (800) 644-0858
    2818 Sunset Place, los angeles - (310) 600-6007
    911 Wilshire Blvd, Los Angeles - (310) 399-8484
    I have never used any of these places so I can't recommend them or tell you anything about them. I got them thru Google.com
    Apr 06, 2010 | KitchenAid K5SS Heavy Duty Commercial...
    My eMac doesn't like to restart after being put to sleep or turned off. When the power button is pushed it will beep 3-4 times and the white power light flashes in sets of 3 short lights, and the screen...
    I know emacs have had there times and this might be the cause for yours as well. Do this: turn the mac upside down take off the memory cover from the unit using a screwedriver now you will see 2 round capcitors there check to see if there buldging at the top or leaking for the bottom. Now not all caps leak they just buldge. If this is the case you have a couple options here 1. repair it yourself 2. take the logicboard out of the system (a lots of work) and log on to www.badcaps.net this dude will repair it for $75.00 plus shipping Thanks
    Aug 09, 2009 | Apple eMac G4 Desktop
    MAC G4 won't boot - Blue screen appears
    Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
    You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
    Mar 30, 2009 | Apple eMac G4 Desktop
    Computer will not go into sleep mode
    External drives (hard drive, DVD burner, iPod, USB drive), printer, a worn out mouse button, debris in/on the keyboard, and cats are all things that can cause your computer to refuse to sleep (or wake it shortly thereafter).  Rule out these first.  I have had the same problem in the past.  It is almost always one of these that causes the problem.
    Feb 23, 2009 | Apple Power Mac G4 Desktop
    Need local repair in Los Angeles for MagicSinging Model#ED-9000
    are you getting a green flashing light or none at all..
    if green flashing light then it is the mic signal, if none at all, then it is the transceiver inside. contact me sean.delcarmen@magicmic.com
    Sep 03, 2008 | Magic (ED8000) Professional Microphone
    Computers & Internet Logo
    41 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
