Question about Kenmore 24032\24036 Top Load Washer
Can't remove end caps from Whirlpool Model GST9679PG1 top loader
The console has two end caps that look like there are removable. There is a screw on the back side that looks like it needs to be removed before the end cap will release. However, the top of the screw is not completely exposed. It looks like the screw pushed in plastic tab, broke it and now part of the tab is resting on top of the screw head.
  • bdejong99 Mar 11, 2009
    Worked perfectly!
  • 163 Answers
Take the two screws out.one on each side.then stand in front of machine and pull caps forward and up and your face of the machine will be up.
Posted on Mar 10, 2009
  • mike cooksey Mar 11, 2009
    Glad I could help.
My Whirlpool model sm8525079 will not spin. It will make a humming noise that I assume is the agitator but no real clue. It will drain though.
this is not a modle #,try raising the lid if a top loader and look low center under lid. if top load you may have a broken drive coupling.pretty easy fix once you get cabinet off.2 phillips up front on older on back on some,all at the very out side edge of control panel,some newer have end caps to remove for front screws.newer have spring clips.use putty knife between washer top and panel out side edge.two spring clips remove pump,two screws and clips remove motor,coupling is next.
Dec 10, 2013 | Washing Machines
Tip
Washer Case Removal for Whirlpool Top Loaders
To access the interior components on Whirlpool manufactured top loading washers, you must remove the exterior washer casing. The follow steps, explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in a few different ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
c. Some consoles have a series of screws located in the back. Simply loosen the screws to release the console.
3. Once the console has been released it will lift up and fold back over the back of the washer to its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
IMPORTANT: To correctly reinstall the washer case, follow these steps:
1. With the lid of the washer casing open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame base in the front.
2. Lower the washer casing back onto the side frames. Make sure the small cleats on the side frames fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
3. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you to seat it.
4. Reinsert the brass clips. Place the 90 degree bend of the clip into the slot on the back of the washer first, and then forcefully push the J-hook end of the clip down into the opening on top of the washer. NOTE: Once the clips are snapped back into place, the washer case should fit tight and not move on the frame.
5. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
6. Reinstall console.
These procedures are much easier than they appear. If you have any questions, please let me know. I hope this information is helpful.
NOTE: Whirlpool manufactured top loaders include Kenmore, Roper, Estate, Frigidaire, Kitchenaid, Kelvinator and some later model Maytags.
on Dec 13, 2009 | Washing Machines
Need to take the top off to change the switch that allows the machine to start.
If this is a Kenmore top loader and you are referring to the LID SWITCH, the follow link explains step-by-step how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you are referring to the TIMER, you need to open the operator console. This is accomplished in several different ways depending on the model washer:
Once the console has been released it will lift up and fold back over the back of the washer to its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily. The timer can be accessed by removing the control knob on the front panel and removing the mounting screws. Once the mounting screws have been removed, you can postion the timer to unplug the electrical connections easier.
If you require additional assistance, please post back with your complete model number (located on a nameplate along the wash tub rim under the lid) so that I may be able to determine how your washer is configured. I hope this helps you.
Jan 05, 2010 | Washing Machines
How to take back & top off washing machine
If this is a Whirlpool TOP LOADER, the back of the washer is not designed to come off. These washers are designed to have the entire cabinet come off in one piece. Its a failrly simple procedure. Just follow these steps:
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
b. If the console
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp the case under the front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If this is a Whirlpool FRONT LOADER, the top comes off by removing the screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
The rear of the washer will come off by removing the series of screws around the perimeter of the back panel.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please post back with your complete model number (located on a nameplate around the tub opening - top loader, around the door opening - front loader) so that I may be able to provide you with better assistance. I hope this information is helpful to you.
Oct 18, 2009 | Washing Machines
Kenmore Stylemaster 4217013 top loader that will not spin.
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2009 | Kenmore Washing Machines
Kenmore model 11092587210
The following link explains step-by-step how to replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have questions, or need additional assistance please let me know. I hope this helps you.
Sep 16, 2009 | Kenmore 24032\24036 Top Load Washer
How to remove the control panel on a whirlpool washing machine
If this is a TOP LOADER, the operator console comes of in various different ways:
1. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
2. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. On some consoles there will be a screw located in the rear on each end that you need to remove in order the lift the console.
If this is a FRONT LOADER, the console is removed in the following way:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console2.gif by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
If you have any questions, or need further assistance, please let me know. please include a model number so that I may be able to provide you with better assistance.
Sep 07, 2009 | Washing Machines
Kenmore elite top loader keeps getting stuck in all cycles....
May 09, 2009 | Kenmore Washing Machines
Older Style Top Loader Washing Machines
if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
142 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
