FixYa.com
Tags:
Sony SRF-M95 AM/FM Radio
Why is a battery needed in a radio receiver
By Odud - usenet poster
if we take a simple radio receiver, at which stage of the reception
process is the battery needed? the antenna does not need a battery,
that i know, the amplifier does need it - that is also obvious, but
what about all the things that happen in the middle? ( tuner
(capacitators), detector (resonator) etc. )Which is the first element
that will prevent reception if the receiver is not equipped with an
external power source?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Grant
Grant - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi Jeff,
thanks for the post. It is a theoretical question - I am discussing
with a friend (who is a an electrical engineer that already forgotten
the basics :) ) why we need a battery in his walkman. He says that it
is needed only for the amplifier, I say we also need external power
for the resonator, otherwise it won't oscillate.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
On 12 Aug 2002 01:14:02 GMT, (Dbowey) wrote:
Y'er right, I goofed. (I hate it when that happens). I forgot about
the first local oscillator. It would be the first component in
receiver chain that would require power.
Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
(831)421-6491 pgr (831)336-2558 home
# WB6SSY
-cruz.ca.us
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
Some require a battery for memory of preset stations.
Other than that, each stage of amplification, input to output,
signal processing, whatever requires some power supply.
Jeff
Solution #4
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
<< If your unspecified receiver has a passive front end mixer stage
(double balanced mixer), there is no power required at the mixer
Say, Jeff, you seem to ignore the local oscillator that will be driving the
double balanced mixer. You might want to take another look at your mixer
theory.
Don
Solution #5
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
On 11 Aug 2002 04:57:21 -0700, (sara) wrote:
Is this a theoretical question?
There are such things as "free power" receivers, that do not have any
external power source. The problem is that without amplification, the
power output at the speaker/ear-phone is no more than the detected
power at the antenna. In general, they pickup power from ALL radio
stations, rectify it, and use it to run the amplifier stages of the
receiver.
(double balanced mixer), there is no power required at the mixer. In
1-20MHz receivers, atmospheric noise obliterates the sensitivity
benifits derived from an RF amplifier. Therefore, many HF receivers
have no active components in the RF section and consists only of
filters. So, a simple HF receiver might consist of a passive RF
section, a passive mixer, and a passive first IF filter. However,
after the first IF filter, you gotta have some gain. That's where the
first stage the requires power is located.
I suspect this is not what you're interested in determining. Perhaps
it would help if you disclosed what you are trying to accomplish and
what you have to work with?
# WB6SSY
-cruz.ca.us
Solution #6
Not Rated (0)
kioner
Rating: 0%, 0 votes
There isn't one.
Do a search on "crystal radio".
However, if a sensitive radio, or one that does more than output into
sensitive headphones is needed, then you need to amplify the
signal.
This needs some sort of power.
# | mailto: | Ian Stirling.
If God hadn't intended us to eat animals,
He wouldn't have made them out of MEAT! - John Cleese
Can you Help with these Personal Radios problems?
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
Personal Radios
Audiovox AXR48- find manual?
I can't find a manual for my... Answer This...
Personal Radios
Need replacement earpads for...
Hi, folks....My radio is a few... Answer This...
Personal Radios
Radio display out on 2006...
The sound system on my Harley... Answer This...
batteries
I got a sony clee .  Its 5... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
