Question about Krups XP2010 Espresso Machine & Coffee Maker
Water leaking in espresso machine
I have a Krups XP2010 espresso/ coffee drip machine, and it has been working great for several months now, but all of the sudden, whenever I turn the espresso on, all of the water from the tank is going to the overflow tray, and is getting everywhere. I have been making espressos for a very long time, and have done nothing different for this to happen. I have made sure that the water tank is positioned properly, and that it is filled. I was wondering if anyone knew what was causing this and how to fix it.
  • artfully108 Apr 15, 2009
    This machine is a piece of junk! The espresso maker broke after only 20 uses and the coffee part leaks all over the counte. Unfortunately, the warranty expired (we've owned it for 14 months but have only used it for 11). I would not adivse ANYONE to buy Krups products, because the company does not stand behind them any more.
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
Posted on Jan 07, 2010
  • 3 Answers
To open back side:
remove 6 cross screws
Sides are now loose but top and bottom are fixed by a plastic flange of 2mm. simply pull the back cover off with fingers hooked on each side, the cover will flex. Otherwise cut the bottom flange with a knive and use some duct tape to fix it later at that spot.
Posted on Jan 06, 2014
How do you get the back off? We've got the same problem.
Posted on Aug 11, 2010
Having same problem PLUS now the pump doesn't seem to want to work. Takes forever to decide to try to pump, makes some labored thumping groaning sounds, sends LOTS of steam out around the side of the coffee grounds holder but no more espresso. I can't find anywhere to get a replacement pump. Any ideas?
Posted on Sep 19, 2009
Fixing a leaking Krups XP2010
i have only read the first bit but the problem is that were you have the coffee filter holder you also have a seal which you have to change
Oct 15, 2014 | Krups XP2010 Combination Unit; 10 cup...
How to seal a leaking krups espresso machine xp2010
as far as i know your best shot is to take the hose with you at a car parts store and ask them or high pressure fuel line with the correct size but dont thell them that its for a cofee machine
How can i open the back panel of the kruos xp2010
To open back side:
Sep 29, 2013 | Krups XP2010 Espresso Machine & Coffee...
Hi, I just got the Krups XP2010 Espresso Machine & Coffee Maker, but it didn't come with the manual. How could I possibly get it? Hope you can help me get...
This was very difficult to locate, but I found it just for you! :) Please rate my answer 4 thumbs up on the site here, it is very important to me. I would be forever grateful. Here is the manual for you, please give it a few minutes to load it's a somewhat large file. If you need it emailed to you please respond back to this post and I will email it over. Here is the manual (you will need adobe reader to view it, but you probably already have that installed):
http://www.krupsusa.com/NR/rdonlyres/B454517D-7214-428F-BE57-932CFACB3E97/7240/XP2010.pdf
Oct 12, 2010 | Krups XP2010 Espresso Machine & Coffee...
Where can I order a krups xp series seal MS-0A01503? It is a seal for the plunger that expels the coffee cake after brewing. It started to leak and I need to replace it.
Nelson Appliance has this: http://goo.gl/bsjqj. I think this is what you are looking for. The description they give is: Boiler center gasket / seal #MS-5015004 for use with Krups XP7000 series espresso machines.
Aug 31, 2010 | Krups Coffee Makers & Espresso Machines
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP2010 Espresso Machine & Coffee Maker Logo
897 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
