Question about Canon CFX-L4000 Plain Paper Laser Fax
I can only receive faxes not send when i try to send it just keeps ringing will not transmit
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
If you dial a number and just hear ringing that means the other end is not answering. Even if a person or answering machine picked up the ringing would stop. The problem is at the other end.
Posted on Mar 14, 2009
Canon MX850 won't transmit faxes.
maybe there is no response on the other side, try to send fax to another number
Oct 29, 2014 | Canon PIXMA MX850 Multifunction Printer
Cant send fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | Samsung SF-565PR/XST Printer
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Jan 26, 2010 | HP Office Equipment & Supplies
Peoplel are sending me very imp. faxes and idk how to recive it..
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
Oct 04, 2009 | Canon MX310 Office All-In-One Printer
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
Aug 25, 2009 | HP Hewlett Packard Officejet Pro L7680...
Get communication problems when sending some faxes - when sending faxes to some places it won't transmit but will transmit to other places
The problem can be either a error with your phone service or an incompatablity with your machine and the receivers.
Sometimes the problem is as simple as the receiver's machine being set to receive on more rings than your's before it goes into redial.
Apr 15, 2009 | Office Equipment & Supplies
LEXMARK X5495 New printer, can't send receive faxes
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
Jan 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can not transmit faxes
do you have a seperate fax line? if so check the fax line.
also in the fax menu set up your fax to phone/fax mode, and set up all your fax info.
if you have distinq ring you need to set up your # of rings.
Feb 22, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Sep 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon CFX-L4000 Plain Paper Laser Fax Logo
75 people viewed this question
old marine
old marine
