Question about Garden
I have a Scott s2046, when I pull the choke to start it
I have a Scott s2046 made by John Deere, when I pull the choke to start it starts fine. When I push the choke back in it will stop running. need help.
Thank you
Bill
Did you recently change the fuel filter? When I changed the fuel filter that used to happen to me. What worked for me was loosening the gas cap and it would continue to run, over time the fuel filter soaked in the fuel more and the mower ran fine, give it a shot. Good luck
Posted on Apr 21, 2010
John deere riding lawn mover doesn start, said, code 7.6
Gas is bad these days. If it's turning over but not starting, Pull the plugs and replace, they are cheap. Drain the gas out and add high test with no ethanol. Add a couple drops of a fuel jet cleaner. Turn it over a couple times. Don't panic if it does not start leave it sit overnight, then start. Check the gas filter and air filter as well. Nothing here expensive. Unlikely anything else wrong unless someone was paying with the carburetor or choke.
Oct 13, 2014 | John Deere Garden
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
JOHN DEERE 265 LAWN TRACTOR STARTS HARD
has to be not getting enough gas take air filter off pull the choke and see if the throttle plate is closeing if not that's your problem
Jan 27, 2014 | Garden
John Deere LX188 fuel mixture or choke problem
Try slackening the fuel filer cap to make sure there is not a vacum building up
May 30, 2013 | John Deere Garden
I have a scotts/john deere s2046 riding mower (man date 12/98) --hydrostatic trans making a groaning noise--want to fix it before it fails--is there a rebuild kit of some kind?
I would try and fill the case with 50 weight oil It might be low. The hose should come to the right side of the pully door on the middle of the tractor between your legs.
Terry
Jan 09, 2011 | Briggs & Stratton Starter Scott's Equip...
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
