hi there i will help you first what you need to do is get a screw driver open the printer up strip it down then get to the cartrage then u shuld beable to deal with that then put the case and everything back in aprt from the cartrage then when you have done that u need to put the cartrage back in it should pop back in just means one of the termimnal are making lights flash about if you need anymore hel p let me know [email protected]
Unfortunately the service manual does not have this code listed. Maybe its an F2-?? or F5-??. Please reconfirm and respond. if you hold down the copy key it will display two more numbers.
Usually you press Start 3 times to turn the child lock on, and press Stop/Reset 3 times to turn it off. If that doesn't work, you can probably unplug it for a couple of minutes, then reset the clock.
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Hi i think the problem code for f2 problem is to enter this code pressing * interrupt CA interrupt then the light will go of then you enter 80 then press copy and 1 copy.
how to do that??
