Question about Ricoh Aficio 350e Printer
How do you update the time stamp on faxes/fax confirmations on a Ricoh Aficio 350?
Should be under "user tools", "System settings, "timer settings"....."time/date", or something like that
Posted on Mar 10, 2009
  • ex_copiers Nov 05, 2010
    On aficio 350 has not timer settings in System Settings because has another menu is not touchpad,.....
Every time I fax out, there's a confirm report print out. How di I turn this off?
To disable a confirmation report each time you fax, you need to make a change in the Parameter Settings. To do this, perform the following:
  • Press User Tools
  • Using the up and down arrows, select Fax Features
  • Press OK
  • The "switch" you need to modify is switch #3.
  • After hitting OK, use the arrows to scroll down to switch 03.
  • Once there, press 00
  • Press User Tools
Your machine is now set up to fax without printing a confirmation report. The transaction will still be stored and can be made part of a more general report.
Mar 08, 2011 | Ricoh Aficio MP 2000 Black and White...
I have a RICOH AFICIO 2045e Multi-purpose printer/scanner/copier. I would like to know how to set up a custom STAMP for when we receive a FAX transmission, i want to customize it to where it says the name...
Hi
This is possible through the control panel, however a bit complicated to describe here.
Try downloading the User Manual from the Ricoh Website. They are there, and free.
Dec 07, 2009 | Office Equipment & Supplies
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 350 change number of rings before fax answer and/or auto detect incoming fax.
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
Mar 25, 2009 | Ricoh Aficio 350e Printer
Fax confirmation
check the settings in the paper tray. Do you have a manual? Should be info in it to change paper specs.
Aug 23, 2007 | Ricoh FAX5000L Plain Paper Laser
158 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
