Question about KitchenAid KAWS850L Top Load Washer
KitchenAid KAWS850L Top Load Washer - wouldn't spin, replaced the coupling, did 3 loads and smelled like something electrical burning. Took it apart again and checked everything, seems ok. Put back together, turned it on, it filled and stopped, wont do anything. Had repair man out and he says its the motor. Not sure I agree, he wanted 300.00 to replace the motor! Any other ideas on what the problem is? Is it worth checking the capacitors or anything else??
    Scholar:
  • 102 Answers
Check and see if one of the wires came off the capacitor on the motor. if one of these wires come off then it won't spin also make sure that your lid switch is hooked up and working properly. will it fill with water?
Posted on Apr 02, 2009
  • KitchenAid Master
  • 3,361 Answers
The motor is $200.00. You could replace it yourself.
Posted on Mar 28, 2009
Spin cycle doesn't spin
what kind of washer is it top load or front load and brand.?
May 26, 2012 | KitchenAid KAWS850L Top Load Washer
Hallo,I have problem the cycle dosent spin kitchen-aid wash machine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | KitchenAid KAWS850L Top Load Washer
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Machine won't spin
Motor part number is 8529936 about $200.00 any appliance parts store can order it. You can replace it your self. Also replace the direct drive coupling when you change the motor.part number 285753. Be sure to inspect your wiring harness and check the motor wire continuity before you put $200.00 into it.
Mar 27, 2009 | KitchenAid KAWS850L Top Load Washer
Clothes washer just makes a noise like a gear spinning ?
I was having the same problem with mine so I took it apart. There is a plastic coupler-like device that connects the drive motor to shaft which allows your "spin" cycle to commence. This coupler has posts in side it but they are under the little belt. My posts were all broken so the bottom piece of the coupler was spinning but the top was not, so it just made a humming noise. This part is available at
http://www.searspartsdirect.com
partNumber=3363664
Nov 24, 2008 | KitchenAid KAWS850L Top Load Washer
My kitchenaid top-load washer will not spin with a heavy load.
this will sound odd to you, but having done this for some time, i would bet there is something between the basket and the tub. sound impossible, but sometimes thing so get in there.......like lighters! you have to take the agitator out, get a speacial spanner whench to remove the nut holding down the tub(maybe $20 buck) then pull the tub out and see whats in there.
Nov 11, 2008 | KitchenAid KAWS850L Top Load Washer
Kitchenaid top load washer
Have a look underneath and see if the drive belt has fallen off. If it has, check this isn't because the pulleys have failed (look for spoke failure near the hub on big pulleys), then buy a new belt. Putting the old belt back on might keep you going for a while in the interim. A.
Apr 11, 2007 | KitchenAid KAWS850L Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
258 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
