You should got the factory crossover harness would been no colors to match and you wouldnt need cut the factory harness. Crutchfield sells them for every vehicle made. Striped wires are speakers dont hook up the orange wire at all that the illumination black is ground red is constant power
All you need to do is get the power, ground, and antenna hooked up then start with two colors matching, example: one purple and one black with purple line hook those up to a matching speaker wire then turn stereo on and go to balance setting choose back left if speaker does not sound then go back right and if speaker does not sound then try front speaker right and then left once you find correct speaker move on to next two matching remember to. Mark wires FL or fr or bl or back right. Good luck
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
mcdevito75 here, The wires in the instuctions should show what color they hook up to, now just match those wires with the switch, a small tip, hook up a dark wire from the fan motor to a dark wire on the switch, a lite color wire from the fan motor to a lite color wire on the switch as you hook up each pair or wires, cover the bare wires remaining on the fan motor and switch with tape and try the fan to check spped.
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
orange is power
red is egnition
blue is power antena
black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
does this model have the built in amp? brownred may be the clock. do you know what each of the wires on the stereo controls? if you know this i can help you.
either way give me a list of the colors you dont know
do you have a test light?your speaker wires should be four sets of matching color,dark/light blue,dark/light green,dark/light purple and one other matching set of colors. then there should be one black wire which should be ground.with a test light you can find your power and accesory wires. your power wire will always have power with key on or off,the acc wire will only have power when key on. i hope this will help.
