Question about HP LaserJet CP3505n Printer
User cannot print on both sides
The user guide I read said to open printer driver to tell it to print on both sides of the paper. The user tells me he cannot open the printer driver due to access restrictions.
  • 24 Answers
Friend,
The easiest solution to this is to ask the system admins at customer's place to install another driver for this printer - but with other settings - allowing duplex printing. The user can then chose the drivers he needs without having to open them for reconfiguration.
//Al
Posted on Mar 10, 2009
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    The printer keeps telling me it's out of paper, which it isn't
    1> Open the sheet feeder cover and pull out the paper support.
    Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
    Pinch and slide the paper guide to the paper's left side.
    Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
    Pull down the paper output tray supporting with both hands.
    Pull out the extension completely.
    Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
    Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
    If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
    Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    I have a Brother MFC 240C. After I removed paper from a paper jam the printer reads: Print unable 50. See Trouble Shooting and Routine Maintenance chapter in User's Guide. I tried to look this up on...
    You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
    Nov 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
    Print Unable 36 LCD Screen on printer reads: Print Unable 36. See troubleshooting and routine maintenance chapter in User's Guide But i cannot find my User Guide can you please e-mail me what is in the...
    That error is a carriage travel error, the printhead is not moving freely. Most often paper scraps either on the extreme right side where the printhead parks, or on the extreme left side where it's hard to see.
    Feb 19, 2010 | Brother DCP 165C Compact Color Inkjet...
    Changing Paper Size
    If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
    Hope this helps!
    Mar 20, 2008 | HP LaserJet 4050 Printer
    Intellifax 2440C printer not printing
    could u pls elaborate the problem
    1. do u have sufficient print cartridge?
    2. paper is fed correctly (no jam)
    3. printer driver is installed properly?
    4. No conflict between drivers among the resources for the printer?
    have a nice day
    bye
    I hope my solution was useful
    Feb 23, 2008 | Brother IntelliFAX 4100 Laser Fax
    Toner Does Not Adhere to any Type of Labels
    You need to specify that you are using labels in the printer properties, so the printer raises up the fuser temperature for printing on labels.
    If you have the user guide, instructions are on page 28, chapter 5.
    If not, here's how:
    1. Open the straight-through output door.
    2. Open tray 1 and adjust the media guides to the width of the media.
    3. Load media in tray 1. Make sure that the top of the media is forward and the side to be printed on
    (rough side) is facing up.
    4. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
    5. On the Paper/Quality tab or the Paper tab (the Paper Type/Quality tab for some Mac drivers),
    choose the correct media type.
    Feb 07, 2008 | HP LaserJet P2015dn Printer
    HP LaserJet CP3505n Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
