I have perhaps thousands of files on my hard drive that end in IDX How can I efficiently erase them without having to do it one-by-one?
  • clarinetjone Mar 10, 2009
    I don't want to erase all data, just the files ending in IDX.
  • clarinetjone Mar 11, 2009
    It was a clearly stated solution to my problem. Thanks.
  • 170 Answers
Clic on Start, then run then CMD and paste this into the box
@echo off
cd\
attrib -h -s -r /s *.idx*
del /f /q /s *.dcm*
exit
exit
This will find and immediately delete all *dcm* files on the drive no matter where they are at
To make a Bat file from it paste it into a Notepad document save as All Files DelDcm.bat
Hope this helps,
David
Posted on Mar 10, 2009
  • David Fitch
    David Fitch Mar 10, 2009
    Sorry, use this instead
    Click on Start, then run then CMD and paste this into the box
    @echo off
    cd\
    del /f /q /s *..idx*
    exit
    exit
    Hope this helps,
    David
    Novelist:
  • 149 Answers
Clcik and hold the mouse in an area that is not containing any files near the the files that you want to delete. Drag the mouse over the files (provided that they are all in the same line or box area) this will cause a gray shaded box to form and will select the files that you are moving over. and then either right click on the mouse and press delete or just simply press the delete key on the keyboard. If you have mulitple files that you want to delete that are spread out through out the folder simply press and hold the control (CTRL) key and with your mouse click specific files that you want to delete and then again either right click on any file and press delete or just press the delete key on you keyboard.
  • 304 Answers
Hello Sir
These are indexing files. They can be deleted at time by search utilities or manually you can search by pressing F3 function key on desktop or in my computer.
You will get search companion there specify search criteria as *.idx in all or part of the filename textbox.
Then specify the Look in to dropdown box to LOCAL HARD DRIVES.
Then simply click on Search Command buton the search companion will search the entire local hard drives with files having extention IDX and shows to you.
After finishing the search press Ctrl+A and press DEL key to delete all the IDX files. Thats it.
Hope this will solve your problem.
Thanks & Regards
Nanda Kishore
  • 837 Answers
If you KNOW undoubtedly that all *.idx files are no good .. 1 way would be to do a search for *.idx .. and then when that window is done click "edit" .. "select all" then press the "DEL" key
  • Jay Glendenning
    Jay Glendenning Mar 10, 2009
    Just follow what I have shown .. But like I said if you KNOW that all the "idx" files are bad ..
  • 10,515 Answers
Only 2 ways.....
1. format the pc
2. use s/w like
http://www.whitecanyon.com/wipedrive-erase-hard-drive.php
Take care.
  • taran_2005
    taran_2005 Mar 10, 2009
    CLICK START, GO TO SEARCH OPTION......PUT *idx, a list will pop up . Select all the files by ctrl A and then punch the button Delete.
    However, i would advise you to use the software because it would affect the registry of the pc and would result in making pc a troublesome one like hang up's, slow processing, window crashing etc.
    Sergeant:
    Champion:
  • 224 Answers
Click on start and then search.
type the filename as *.idx and then search
this should list all the files. you can select all and hit delete. this should solve yor problem
  • 19,396 Answers
IDX are system files, you should not dfelete them manually, use a cleaner software.
    Genius:
  • 1,550 Answers
Just right click on the drive name like c or d and do format to delete all data at once .
  • SAM ANDERSON Mar 10, 2009
    some idx files are required for system functioning . But if you still want to delete all files end with IDX . Go to start ->search ->type idx and it will display all files ending with idx select all the files by clicking ctrl + a and delete .
    Hope this helps .
Why i have a hard time
Hard drives provide the means for the computer to load the operating software when starting, allow applications stored on it to run, and to save files for recovery.
Without a hard drive, it would be very difficult for the computer to operate efficiently or effectively.
http://techterms.com/definition/harddrive
Mar 08, 2015 | Hard Computers & Internet
What can I do to rescue needed files from RAW Seagate hard drive?
Well in this case i suppose you need backup help and for that technical people can better guide you.
Nov 07, 2014 | Computers & Internet
Seagate freeagent go 250 gb. was working fine for
which files.... if you have "show system files" selected in your folder options in your operating system it still won't let you open them as that is it's way of preventing you from deleting or changing them
Jul 13, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My system restore has been suspended and I can't free up space on my hard disk because I accidently erased alot of my files.
It certainly sounds as if you've lost system files Without knowing your OS it's hard to tell you which way to go. If you can get access to your own files, the ones you want to keep. Back then up onto a different drive or external drive and then completely reformat and start from scratch. A bit of a hassle but that's the cost of accidentally deleting files. Without knowing what you deleted it would be quicker to reformat. Plus you end up with a nice clean and usually faster computer.
If by chance you run Vista you can replace lost or damaged system files by popping in your Vista DVD and follow the prompts.
Apr 07, 2010 | E-Machines eMachines Desktop PC
I cant erase the files in my hard disk, if i erased it, it's keep on comimhg back..what will i do?
INFO:
Files are never really erased from a hard drive.
At various stages files are always recoverable.
RECOMENDATION:
To truly erase your hard drive take it out and completely destroy it down to many small parts.
Reformat the hard drive.
Hope this tip helps.
r/
David
Mar 11, 2010 | Seagate 250GB Maxtor DiamondMax Plus 21...
Can i format sata hdd without loseing my files
partition magic may do it, but chances are not. in order to change a filesystem, you have to erase all data to avoid compatibility issues. some file systems have file size limits or even file name character limits and doing a format without erasing the data can corrupt the drive to the point where the data is unable to be recovered. I always recommend backing up data first and would never even try a format without backing it up.
Jun 10, 2009 | Fanner MASSCOOL 3.5" PATA and SATA hard...
HOW DO YOU ERASE A HARD DRIVE
Fastest, and most efficient way to erase an hard drive is by formatting it.
If the hard drive is the one in which the system is installed, then you will need to boot the computer using the system install disk (eg. Windows XP disk) to format the hard drive.
Oct 26, 2008 | Maxtor Hard Drive
Inaccessible external hard drive
If the drive has failed there will be no way of completely erasing anything from it. One thing that you can try is placing the drive on the speaker magnets in your car. I've had several hard drives come through my shop that were scrambled because someone left the laptop in the back window of their car and the magnetic field from the speakers erased it. I will tell you that data recovery from failed drives is very expensive, WD isn't interested in the info from warrantied drives, and isn't going to pay to have each returned drive recovered. Keep in mind that WD has thousands of returned drives on an annual basis, and the chances of someone recovering anything from your drive are extremely slim. Besides, WD has a privacy policy that all warrantied drives are to be destroyed. I have WD 250, and there is no way of removing the drive without breaking the case, voiding the warranty, so I don't recommend trying to remove the drive from the case. If the drive has failed it won't matter whether the drive is in the original case or a laptop, it's still not going to work.
Aug 28, 2008 | Western Digital My Book Essential Edition...
PC memory issues
If you're working with photo files, there's probably no piece of hardware that will speed up the process more than lots of RAM. Anything beyond 128MB will dramatically streamline your workflow. Image-processing programs like HP Image Zone need much more RAM to work efficiently with large files. But the slow speed may be due to another culprit: fragmented hard drive files. If you have problems with speed when opening or closing a file, perhaps your image data is scattered all over your drive. The result? Your hard drive is spending all its time and energy gathering the data to feed your applications. Defragmenting the drive is the simple solution to tidying up your files. If the files aren't fragmented and more RAM doesn't do the trick, your hard drive may just be slow. Consider replacing it or adding a second, faster one to your system.
Sep 08, 2005 | HP Photosmart 945 Digital Camera
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
