Question about Water Heaters
Water heater replacement
My wife's salon has an electric water heater now, would like to go to gas.The problem is there is no easy access to the roof to vent, furnace is high efficient so it is out the side wall. Other than going with the expense of a heater with a blower is there another way. thanks in advance Andy.
  • 252 Answers
Direct vent water heater is your best option with gas - may be best to stay with electric - today's electrics are more efficient.
Posted on Mar 12, 2009
Gas water heater vent pipe has shifted after a roof was replaced. It is urgent that it be fixed immediately or is it ok if there is a 18-20 hour delay? Are there any dangerous fumes?
carbon monoxide is the deadly gas produced
It is odourless and settles in lowest palces
You just go to sleep and never wake up
The vent has to be replaced immediately and the person doing the roof work would know that importance of the vent if he was qualified to do the roof work
You can reduce the risk by keeping windows and doors open to allow for proper ventilation
Feb 23, 2018 | Water Water Heaters
Easy way to replace it
Replacing a water heater is no very difficult if you follow the steps.
1. If it is electric turn of the breaker and check to be sure it is the right breaker. If it is gas turn off the valve close to the water heater.
2. Turn off both the hot water and cold water valves
3. Drain all water out of the heater.
4. Disconnect the electric wiring if electric and if gas disconnect the gas line.
5. Disconnect both water lines which may have to be cut depending on how they are connected.
6. Now you can remove the water heater and discard.
7. Place new heater where old one was removed and reconnect both water lines and be sure you have a new pressure valve installed on the water heater.
8. At this point you can turn on water and check for leaks. you should also open a hot water faucet to purge the air out.
9. If no leaks go ahead and hook up the electric or gas lines and if gas is used turn it on and check for leaks using a leak detector or a spray bottle of soapy water and look for bubbles. If no leaks you can go ahead and light the heater according to its instructions.
10. If electric is used turn it on.
11. Take a long hot shower.
Feb 01, 2016 | Water Heaters
I own a salon and have 2 Rheem 60 gal 50,000BTU Gas hot water heaters. I am still running out of hot water during the work day. My question is because the hot water heaters are on the 3rd floor, it is...
I think before I spend the kind of money to get a tankless added I would get the rheems serviced . two should produce more hot water than 30 people could shower with all day
Feb 21, 2015 | Rheem Water Heaters
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
I have a richmond gas hot water heater 6g40-36f1i want to know where is the outer door located at so i con turn it on
The gas pipe should have an accessible valve to turn off the gas.
This is gas so you have to read the manual. There is no easy way around that. You are responsible for knowing the contents of the User's Manual, including the safety warnings.
With electricity you can only kill yourself but gas includes a force multiplier so that you can injure other people as well.
Sep 29, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
My hot water heater won,t stay lit
Question posted under Reliance tank-type gas water heater.
Look at label on side of unit and add comment with brand, model and type heater, because the answer depends on which brand and type water heater you have.
Information below is for Reliance tank-type.
First of all, you need to clean the air intake located on bottom of unit.
The fact that the pilot will light indicates that you are getting gas, but the gas control might be bad, or the unit suffered FV failure from overheated combustion chamber and might require part replacement.
To get a good gauge of situation, clean the air intake first, and then add a comment.
Look at image for inspecting air intake.
Then use feather duster and/or compressed air to clean flame trap, arrestor screen (air intake)
ADD A COMMENT with more detail.
Additional resources:
Sep 26, 2012 | Reliance & 30 Gal LP Gas Water Heater
Our Rheem gas water heater was acting finicky a few months ago so we called the manufacturer and they sent us a new/replacement kit for the Invensys WIPER Electronic Control & FV Sensor. We replaced...
You're probably in for a service call and/or possibly water heater replacement if unit is more that 5-6 years old.
Your water heater plugs into outlet. Check outlet with cheap circuit analyzer to make sure the unit is receiving correct polarity without line interference.
If unit is in the attic, then add more venting to soffit and roof so pilot is not being snuffed out by hot air. If unit is in basement, then open some doors and a window and see if unit needs more air.
Most gas water heaters require yearly cleaning and service.
Clean the combustion parts and tubes.
Clean the air intake.
Have gas company check gas pressure.
Open following link for possible illustrations:
The problem can be bad gas control valve, air in gas line, low gas pressure, gas shut off handle not fully parallel with gas line, dirty combustion parts, lack of combustion air, improper venting. Or combination of all things. It's an electronic gizmo, anything can be bad or shorted, and repair may not last long.
Without a trained service technician to ohm-test the parts using correct service manual, then we are guessing at the cause.
Power vent water heater implies that you have side wall venting which must be replaced with another side-wall vented unit -or- it implies rapid reheating of water.
If water heater is more than 6 years old, you might be money ahead by installing a new one from local box store. Avoid the power vent and electronics. Local box store will have passive roof-venting type water heater BUT box store does not sell side-wall power vent. If your power vent goes up through the roof, then box-store variety gas water heater will work. Total cost $350 do-it-yourself for 40 gallon gas.
Or get 40 gallon 240Volt electric for $220 and connect to circuit breaker box. Requires no venting, and is easy to repair for years to come.
Or small 120Volt electric that plugs into outlet to tide you over until gas repairs can be made.
Look for scratch-n-dent models and always offer 10% off.
Shower uses 5-9 gallons hot water.
Aug 01, 2011 | Rheem Water Heaters
Water Heaters Logo
96 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
