Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
On a Designer Style top freezer fridge, what is the switch for Power Saving? It says, less power, or otherwise less moisture (red light on).
  • nvalbers Mar 10, 2009
    Thank you muchly! I thought it had to do with the auto defrost. How does that work?
    You are very helpful folks! I care a lot about energy and efficiency so now I understand my unit. CHEERS. Norm Albers
  • 410 Answers
The power saver switch is used to activate a low wattage heater in the center rail between the freezer and refrig door to prevent moisture build in hot humid locations. if you live in a dry arid location then using it on pwer saver will save you some money on your power bill. if it sweats between the doors then the switch needs to be set to  reduce moisture to prevent mold and mildew build up on the seals and the water dripping on the floor. thanks Peyton
Posted on Mar 10, 2009
  • peyton thompson
    peyton thompson Mar 10, 2009
    the automatic defrost works off of a timer or a circuit board (depending on the refrig and manufacturer). this control determines how often and how long the unit goes into and stays in defrost. it is seamless and you will probably never catch it in defrost. if you do atch it in defrost you will hear what sounds like water runing and hear a sizzling or crackling noise. on some units you may even see something glowing red in the freezer section. this is all normal and nothing to worry about. Thanks peyton
I have a LG fridge freezer that wont stop beeping any help would be greatful model number..GWB227WLQA
Most new style have a warning tone that door is open.
start by manually pushing any door switches ( interior lights should go out). If light stays on you have faulty switch.
Freezer with no light a little harder, but if you have meter and are able to get switch out you can test for continuity.
Not sure of voltage to switch so remove power to fridge while removing switch.
With power removed ( unplugged) you maybe able to remove switch and connect wires together with electrical tape. Plug unit back in see if alarm is off.
Remember if not comfortable with that process call service.
Sep 22, 2016 | LG Refrigerators
I have a GE Profile (#PSC23SGRB) side by side refrigerator that is about 7 years old. The light comes on when I open the door of the fridge and freezer but that is all. The whole thing is dead. Not cooling...
The freezer switch/thermostat is almost certainly bad. If you are sure your turning it on, and nothing happens, it is very likely bad.
If you have a multimeter, you can check and be sure that your getting power to this switch...and then with it in the "ON" position, check for power through the switch.
If you do not own a multimeter, you may wind up saving money to go ahead and call a service man. Otherwise, just to replace a part that you cannot check is a roll of the dice.
Mar 23, 2012 | GE Profile PSW26P Stainless Steel Side by...
Why dont the lites in reftig work --I replaced
Good day,
If both lights went out at the same time, then it is normally the light switch which is located front and usually top of fridge compartment.
First, test the old bulbs in a lamp ect. if O.K. then you will have to change the switch.
It pries out, but is usually broken in the process.
Do this with the machine unplugged, since the power to the switch is always hot electrically.
But before anything else.......
Make sure the new bulbs are snugged in well. They form a moisture seal, and must be tight.
Dec 31, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
We just bought this house and the fridge that came with the house is a whirlpool designer style. The problem we are having is that it's leaking water all over inside the fridge and it's coming from the...
This is a common problem with old top mount refrigerators. The foam between the the two cavities starts to break down and sweat due to the differences in temperature between the two cavities. You can try emptying the unit, turning it off for a couple of days and leaving the doors open giving it a chance to dry out, if the condition returns after a short amount of time, then it is time for a new refrigerator, there is no cure for the breaking down of the Styrofoam inside the unit
Jun 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Samsung american style fridge freezer power loss after internal light blew
try to unplug for 2 min and plug back in to reset the unit otherwise sounds like you cooked a board
May 20, 2008 | Refrigerators
Servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
140 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
