Question about GE JVM1630 Microwave Oven
Panasonic Slimline Stainless Steel Combination Microwave
There is a small hole on the top metal wall of the microwave can this be repaired and is it dangerous.
    Problem Solver:
  • 5 Answers
First of all, is the hole a factory one that you never noticed before? If so, leave it alone. I know that microwaves generate a lot interior heat and it needs to escape someway. Secondly, if it is not a factory made vent hole and you can't be sure if it caused from a lot of use, and if the oven still works fine, I would not worry about it if it were me.
Posted on Apr 17, 2009
Tip
Using stainless steel utensils in a microwave oven
Every one knows that one cannot use metal utensils/bowls in a microwave oven.
But did you know that this does not apply to a utensil/bowl made out of stainless steel?
Try it this way.
Put some water in a stainless steel container and place it in the microwave for 5 seconds.The water will heat up without any sparks being created.
One could actually heat up anything in this way without any danger of causing a fire.
on Apr 10, 2014 | Microwave Ovens
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Panasonic NN-SN960S, turntable won't stop spinning. Have to unplug after every use. What kind of repair does it need and how much would it cost?
May be a door switch problem, or may be a control board problem. You might even have a shorted wire that goes to the turntable motor. (I have seen 1 of the wires get pinched and cut by metal guards or guides that were meant to keep the wires in place.) You can remove the screws from the bottom of the microwave oven, and drop the bottom panel down to checked for pinched wires. Unplug the microwave first before you do that.
Oct 18, 2014 | Panasonic NN-SN960S Prestige Stainless...
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Pin hole in back wall from metal carousel hitting wall while oven on
You can buy stainless steel tape from many hardware stores, just make sure that you put the tape on the outside (be very careful when opening the oven up). Put enough layers on to match the thickness of the metal originally - unfortunately the tape tends not to stay on for that long, so is potentially a dangerous option the best thing to do would be take it to a microwave repair shop - they will have metal sheet available of the appropriate type and should be able to patch it for you - if you get really lucky they might have the same model that has an undamaged chassis but destroyed electrical workings - is worth a try. Good luck Hope this helps - please post again if you need more info :)
Apr 18, 2007 | Dacor DCM24SS Convection Microwave Oven
GE JVM1630 Microwave Oven Logo
183 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
