Question about Dell E176FPC 17" TFT LCD Flat Panel Monitor
Everythings working. no monitor display
Computer working ok. No desktop no display on monitor
Push(+) on monitor and messages something about being in safe mode and to hit any key on key board or mouse. Nothing happens
  • gaggg Mar 10, 2009
    dell moniter - no display
debbily
  • 101 Answers
SOURCE: Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Posted on Oct 14, 2007
  • 58 Answers
SOURCE: black screen- undock the computer message
go to safe mode and return the settings back to day when it was all working fine. Use system restore.
Posted on Feb 16, 2008
  • 46 Answers
SOURCE: Monitor in Power Save Mode
The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Posted on Jun 21, 2008
  • 3940 Answers
SOURCE: No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Posted on Jul 01, 2008
skotkolr
  • 558 Answers
SOURCE: Monitor is in power safe mode
your resolution is set too high go into safe mode and turn the resolution to min and then play with it until it shows nothing push the space bar and leave the setting on that
Posted on Dec 09, 2008
Hp d530 display out
I would unplug the video cable from the computer to the monitor. turn the monitor on and see if you get a message on the display stating video loss or something like that. this will determine if the problem is with the display or the video card in the computer. If you get the video loss message, then the display is good and the problem is with the video card / VGA port on the motherboard or the computer is not fully booting up.
Oct 06, 2013 | HP Compaq d530 PC Desktop
Computer turns on ! No display ! Did system restore and No Display
first thing how did you do a system restore without display? second thing unplug your display from the power and your computer then plug it back in making sure that the plugs are all the way in. then check that the monitor is switched on it should says something like no signal found, now turn on your computer, if you still dont get any display try to test the monitor on another computer or laptop with an external display socket. if the monitor works on another computer then you need to look at video card. if it is an onboard video card then you are probably out of luck and will have to buy a pci or pci express(pcie) card for it. i know that SR2013WM comes with integrated graphics so if thats what your using then just buy a graphics card and you will be up and running again. if you play games then get one with at least 512mb and also one that has a fan i have found that the ones without fans can heat up and slow everything down. ok i hope that helps let me know how you go.
Jan 20, 2011 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
ACER MONITOR SAYS 'NO SIGNAL'
Hi Denise!
First things first, try the monitor with other computers.. If the monitor is functioning then there must be something wrong with the VIDEO CARD or BUILT IN VIDEO ADAPTER for the computer. My guess would be the video processor is not working and one probable solution is to purchase a new video card.
Second Case:
You might have changed the video resolution into something it cannot display. Like setting a 1280pixels x 800 pixels @ 32 bit. to a 15" monitor. 15" monitors or any other monitor in this case may not have support for higher graphics. Stick with 1024 x 768.
Solution: Reboot the computer on safe mode and set the necessary display settings to the lowest.
Hope this gives you an idea.
Mar 15, 2009 | Acer AL2216WBD LCD Monitor
Acer Model AL1916W A reads no signal after being on for 1 hr
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
After many faults my monitor is not receiving signal from my computer
Unplug your VGA cable and Switch on the monitor. It Should display a message that Cable is not plugged in like. If that message comes then monitor is alright. Once again plug and check the VGA cable of your monitor. If it works than its ok. Otherwise there is a problem in your display card which is present in the motherboard. You can insert an new display card or graphic card into your motherboard. Thank you.
Sep 09, 2008 | Computers & Internet
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Dell E176FPC 17" TFT LCD Flat Panel Monitor Logo
54 people viewed this question
Alun Cox
