Question about Radio Communications
Motorola gp-68 low battery beeps comes on too soon
I need to reset the threshhold on my gp-68 radio so the low battery beeps comes on later at a lower voltage .
  • 14 Answers
I'm not sure that you can manually reset the low voltage threshold on your radio. Most of Motorola radio use programming software to turn on/off low battery beep and many other features. Everything is done by software.
radcom907
Posted on May 06, 2009
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Frequency help
sounds like this radio is in 440 band and you won't be able to input any frequencies lower than 4300000.00
Apr 11, 2009 | Radio Communications
Looking for user guide motorola gp-68
Hi!
You can download the user/instruction manual from this link---
Motorola gp-68 Manual
Please rate this solution as FixYa if you find it useful.
Thanks
Rylee
Mar 08, 2009 | Motorola Radio Communications
Motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
Oct 23, 2008 | Radio Communications
Motorola gp 68
Batlabs at http://www.batlabs.com/2way.html (Hand Held Radios) has the GP-68 users guide(Operation Guide), on the right side I think what you might be asking is in "Basic Operation 2", if not look into the Programming section below it.
Strange sound coming from walkie talkie, strange beeping
Most Motorola radios give a beep-beep when the batteries are low and need changing. Make sure to use a good brand of battery. One other thing to check for is leaking batteries, the crud with cut down on performance.
Oct 20, 2008 | Motorola Walkie Talkie 2-Way Radio
MOTOROLA TWO WAY RADIO GP-63
Go to http://www.batlabs.com/gp68.html the manuals here should get you going. if not find someone with a frequency counter. this is alot easier than getting software for the radio.
Oct 02, 2008 | Radio Communications
Radio Communications Logo
315 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
