Question about Roper RS25AEXLQ Side by Side Refrigerator
Roper fridge is not cold enough now.
I have Roper fridge (RS25AEXLQ) since 2003. Several months ago the vegetable section became iced and top section was not cold enough. Now, a whole fridge is not cold enough. What do I have to do? Please provide me parts #s.
  • Roper Master
  • 3,361 Answers
Check the back wall of the freezer.
Is it iced up?
If yes, replace the defrost parts.
Posted on Mar 10, 2009
My roper refrigerator freezer ices up and the fridge is not cold. Model RT14BKXKQ05
You have a defrost problem, could be the timer not advancing, bad thermostat for the defrost system or an open heater. All of these items will cause this issue you have. the only way to find out is to test all the items. If I have to guess, I would replace the thermostat first, but its a guess as I am unable to test them. Good Luck
Mar 31, 2016 | Roper Refrigerators
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
MY ROPER FRIG.ISNT COOLING ON FRIG.SIDE .FREEZER WORKS GOOD
Check fans worrking ok, condenser clear and clean, vents fully open, freezer not iced up solid blocking airflow.
May 19, 2012 | Roper RS25AEXLQ Side by Side Refrigerator
Ice smells funny
Ice cubes are like sponges, they absorb odors. This can be from open food in refrigerator section or a inline filter has fail and need to be replaced and flush out. Your unit has a filter inside the refrigerator section and can be replaced fairly easy. I hope this helps. P# 8171413
Jul 23, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
Freezer section is cold, but the refrigerator section is not
set to colder refrigerator ... not colder freezer!! the fridge is reliant upon air migrating into the area from freezer side! if you peg both controls to max , you get a warmer refrigerator , but colder freezer, the control that does not operate the compressor is the setting i mean, it usually says .. for coldest and everyone pegs it and its a common cause for a service call and people cant believe it, if you cant tell which is which set both to middle! evfen at warmest setting the freezer should still make ice and thats the test for freezers state1 can it make ice!
Aug 23, 2009 | Roper RT14DKX Top Freezer Refrigerator
The divder between my frig and freezer is also hot
This is normal. Modern frost free fridges have heaters built into the front edge of the cabinet to help keep the accumulation of surface condensation and excessive ice build up on the door edges inside the freezer and fridge.
It is nothing to worry about, but you might have an energy saver switch inside the fridge section that you can turn "on" to turn OFF the heaters (energy saver means the power using heaters would be OFF when the energy saver is "on", turning it "off" means the heaters are ON.
But not all fridges have a switch to turn off the heaters, so don't worry, just accept it and don't buy a new fridge until you need to.
Hope that helps, best regards!
Jul 30, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
My ice maker has just about quit working for no reason that I can find
Check to see if water is in ice cube forming tray. If No then probably a bad water inlet solenoid. Water line to fridge goes to inlet solenoid.
Feb 18, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Roper RS25AEXLQ Side by Side Refrigerator Logo
337 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
