Question about Soleus MAC-10K Air Conditioner
The mac 10k works fine but water runs out of the unit
Water comes out of the drain tube after a half an hour of use
  • dmeholic Mar 10, 2009
    I realize that it suppose to condense water but a 10 gallon pot in a half hour seems extreme.Thank you though.
  • 3,361 Answers
It is supposed to condense water.
Posted on Mar 10, 2009
  • steve
    steve Mar 10, 2009
    If your humidity is high...10 gallons is not extreme.
Water on floor after dehumidifier runs for about one half hour either directly drained to sump pump hole or bucket.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers, though.
Hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Dehumidifiers
Water is dripping inside refridgerator coming from inside back center. Why? Sometimes it drips, sometimes it runs and sometimes it's fine.
Is water connected to this unit for the ice maker? If not than this would be the water that comes off the refrigeration coils as the unit defrosts. The water should be collected by a shallow plastic collector, routed to a drain tube, and empties to a pan under the frig where the water will evaporate quickly. Check drain collector for damage and drain hose for blockage.
Mar 31, 2010 | Whirlpool Refrigerators
Water leaking out of unit, not out of flow tube.
Some models have a hose, some don't , maybe the drain hole it's restricted, condensor normally it's in the back of the unit, you might have to remove one of the side panels.
Dec 23, 2009 | Convair Portable Air Conditioner
Licking water on my Royal Sovereign 1000 es
There is a little hole about one inch above the the drain tube and out of it should come a rubber strap connected to a plug for the drain tube. On the far left of the control panel is a diagram of a bucket under a water drop, just below is an led that comes on when the water tank is full and needs to be emptied. I just roll mine out on the porch and pull the plug. Also, when the tank is full the unit should shut off.
Jul 22, 2009 | Royal Sovereign ARP-1000EX Portable Air...
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Jan 25, 2008 | Heating & Cooling
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
A lot of H2O and Alarm
You may have a drain sensor problem. If your machanical you can try to tie the sensor together to see if this allows the unit to run, if so, replace the sensor.
Aug 22, 2007 | Windchaser PAC9 Air Conditioner
Soleus MAC-10K Air Conditioner Logo
180 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
