Question about RCA RT2280 System
"Check SPK" The receiver was working and would radomly shut off. It would shut off easier the louder the volume was. The other day it shut off and when powered back up the display reads "Check SPK". I removed all the speaker wires and tried to power back up but it says the same thing. Any ideas?
  • pksteagall Mar 12, 2009
    Check SPK -- I need a schematic. It may be a emitter resistor
  • 336 Answers
It may have been a bad solder connection on an emitter resistor, now it probably needs output transistors and a resistor or two.
Make sure it's not a speaker disconnect all speakers and power on if it still displays "check spk" it needs service. Est $100 to $140 Total
Posted on Mar 10, 2009
My onkyo ht-r590 goes on then shuts off right away.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Oct 01, 2014 | Onkyo HT-R590 7.1-Channel 3-D Ready Home...
My speaker keeps shutting off when I turn up the volume
make a serial connection with another spk.to double the impedance , then chec again
Nov 04, 2012 | Pioneer VSX-516-K
Volume dial doesn't work well anymore - when turning louder, sometimes turns volume lower or just stays at the same volume level
Some manufacturers allow you to set a max volume limit so you don't blow your ears off.  Check the users manual to see how to turn it off.
Also, have tech support install a new potentiometer for you.
Oct 25, 2009 | Rotel RX-975 Receiver
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
Remote Control #1 will no longer control TV
Remove batteries from remote and put in fresh batteries, this will reset the remote.
Feb 08, 2009 | DISH Network IR Remote Control
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
SOUND PROBLEM
Good Morning
If you set the volume up, and there is a problem with audio, I recomend,
1) reconnect your speakers and press well the conector, (green)
2) see if sound came from output connector using a headset.
3) buy new speakers.
depending on the model of your current spk. check one from creative, they have some good Spk. that work fine for years.
Jan 11, 2008 | Audio Players & Recorders
Shuts down at high volume
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
Clipping amp
hi first disconnect all spks, then turn on the amp. if amp power lite stays on bright then proceed to connect one speaker or sub to the amp. if the amp lite dims during any spk connections then it may be that the spk is faulty or there is a DC voltage (dc offset) emitting thru that particular channel. also check all spk impedance before reconnecting them to the amp. cheers.
Aug 04, 2007 | Alphasonik PMA600HC Car Audio Amplifier
RCA RT2280 System Logo
213 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
