Hello shellytake5 - Often when there is standing water in the bottom of the dishwasher, it is because more than likely the control or drain pump assembly is faulty and possibly need replacing. However, if the unit is making a grinding noise then it is recommended for the drain motor to be diagnosed. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directory to determine what may be causing the issue at hand.
