Question about Evga e-GeForce 8600GT, GeForce 8600 GT, Graphic Card
Problem in wow
Im getting all the fps i could ever want or dream for... but about every 20-30 seconds i have a good lag that builds up a bit and shoots the FPS way down for 5 seconds or so... and its a huge huge problem in a raid i go down to 1fps or lower... and when its done lagging it goes back to perfectnes... i got 400w power supply idk of that would be the problem or not... any answers?
  • 1 more comment
  • shaneman_494 Mar 10, 2009
    e-GeForce 8600 GT
  • shaneman_494 Mar 11, 2009
    i guess i dont know enough what sli means... but i am only running one hard drive that i do know of
  • Eric Lanning May 11, 2010
    What kind of video card do you have?
    Most newer high end video cards require alot more power than 400 Watt.
  • 50 Answers
You can bet that the power supply is NOT pushing out what your PC is demanding. When there is a change in the game that pushes performance, the video card draws more current to process the frames at the speed of the game. (I'm assuming that you do not have a SLI rig). And of course it is a HUGE problem with the RAID. For one, having 2 hard drives writing and reading at the same time takes TWICE the power all the while trying to pump out graphics. More than 2 hard drives, and your PC probably won't even boot (and if it does it will shut down because of overdraw on your psu). My suggestion is to get a MINIMUM of a 650 watt psu, as long as you're not running SLI. If you are running SLI, I would go with a 700 watt or better. But just remember, you get what you pay for. A great DEAL may not be so great in the long run!! Good Luck!!!
Posted on Mar 11, 2009
I have a belkin N150 and my nat is always strict i get it to open by testing my xbox live connection but thats not the hole problem can having such a cheap router cause my bullets on a first person sh
It could be video lag a lot of fps games require a beefy gfx card if you have a good gfx card then it could be you router or service provider go to http://www.systemrequirementslab.com/cyri I use this before I purchase any game to keep from wasting my time
May 04, 2014 | Belkin N1 Vision Wireless Router
Cant even run wow >.> ok, I just bought a gaming
Whats your FPS in wow? (Can be seen by hovering your mouse over the Game Menu sign (the questionmark)).
Is it only low in cities with a lot of players or is it just low overall?
Nonetheless lowering the graphics will obviously help.
Just press Escape to enter the Game Menu, and then press System, and go to the Graphics tab.
You could lower the overall graphics by taking the slider down, but I believe the most important things you should do would be:
Multisampling: 1
Shadows: Low
View Distance: Fair or Low
I would also lower Texture Filtering and Texture resolution.
The thing is I am not entirely sure how the things will change when you use the slider, but I would definitely recommend just trying to slide all the way down at first. If the settings I mentioned above are higher than I posted, I would put them down as well.
Especially Shadows can be a real FPS killer.
The View Distance has no real affect and is just for the looks.
Your PC should be able to run WoW fairly well if you adjust the settings. If you wish to increase the performance without lowering the settings I'd recommend buying some more RAM though.
Anyway, tl:dr:
Press Escape to enter the menu, click System -> Graphics -> turn the slider all the way down to Low. Make sure the shadow settings is in fact on low as well. All the settings under the Effects tab can all clear up some fps if lowered/disabled.
Sep 20, 2013 | Blizzard Entertainment World of Warcraft...
Webcam lag
That website doesn't work properly anymore please help, my nexxtech cam is waaaaaaaaaaay too slow.
May 25, 2012 | Computers & Internet
Have some problems with my asus extrema ax550 card (512mb) ... if i check a systemrequirements site for example systemrequirementslab.com it says a lot of game has to work perfectly in my computer but if i...
So from can i see this card does not have really any true online ratings. However to let you know lag can come from a lot of different places. Memory, processor, having a slow FSB on the motherboard. I mean a lot of thing can play into these problems. You would have to provide a full system build out of what you have to try to troubleshoot any problems not just this video card.
Mar 07, 2011 | ASUS Extreme AX550/TD RADEON X550, (128...
Web cam works, and the microphone works but not toghether when you use both together it doesnt work
The issue could be the fps for your webcam video is low, and the audio continues playing while the video lags a bit. Try going to this free webcam test site. Record yourself for 15-20 seconds and then play it back. Your webcam fps rating will appear below the play back window. If it is less than 10 then your webcam isn't very good and you might want to invest in a better one with a higher fps spec. If the result is more than 10 then your webcam is fine, but the service provider you are using is lowering the bandwidth causing a lower fps result. The only thing you can do is to switch service providers. I hope this is helpful.
Jun 02, 2010 | Microsoft LifeCam VX-1000 Webcam
Lag lag
Have you tried to review the systems requirements for Windows 7? In case you don't, try to review this system requirements and see if your PC falls in. If not, then its the primary cause of the "lag" computer.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Apr 27, 2010 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
ACER Aspire 4520 video card problem
when you play the game turn your graphics down and it will play better like 1260x800 turn it down to 400x 600
Nov 01, 2009 | Acer Aspire 4520-5582 Notebook
Lagging bad on internet low FPS rate
Lag problems wont be anything to do with your monitor, more driver problems or an incompatibility with your new card. Try getting up to date drivers and contact their tech support (the graphics card) and give them your system spec. They will advise if the card is not compatible. This is not about the Windows version, but more about your RAM/HARD Drive speeds.
Also, if your PC had, prior to this install an on-board graphics chip then this can cause problems such as this which cannot often be fixed - try ensuring the onboard graphics is switched off on the BIOS if you can.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Visiontek hd 2400 pro game graphic lag
most computers systems have certain drivers configuration setups for certain games so you dont have that problem.
control panel, open up personazation,open display setting, find advance setting, open the folder that matches the type of graphics card you are using.
open the control center
3d settings
game setting
display options
avivo tm video
power players
graphics: hardware & software options
rod
Feb 26, 2009 | VisionTek ATI RADEON HD2400 Pro Edition...
Lag on my Computer?
i think getting 2gb of ram will make your computer go much faster and wont lag but if u do that ur computer might be to fast for ur graphics so it will look choppy so u might need both.
Jul 13, 2008 | Compaq Presario Notebook
Evga e-GeForce 8600GT, GeForce 8600 GT, Graphic Card Logo
119 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Mike
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
