Question about GE Refrigerators
SIDE BY SIDE GE REFRIDGERATOR RECALL - GE Refrigerators
2 Suggested Answers
  • 207 Answers
SOURCE: GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Posted on Feb 24, 2010
What is the low side pressure for a side by side GE?
This may not be the problem now but by the sound of the malfunctioning unit, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Whirlpool GS6NBEXR Side by Side...
GE side by side 2001 recall
The answer is no. There are no recalls on GE refrigerators. You may view this information at the link below.
GE recalls
May 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
We have a gsh25jftfww ge fridge. the temperature control panel (on front) does not light or work and fridge and freezer is not cooling. The light is still on in the refridgerator, but fan is not running...
Your refrig uses a main control board that is on a recall list .The board uses a WR55X10552 . The replacement board is WR55X10656 . I would suggest calling GE factory service and they will cover this under warrenty , due to the recall .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refridgerator is not cold on the top shelves & door and the items in the freezer top and door are melting.
Sounds like the freezer fan motor stopped working . Usually the main control board is the problem . Part number WR55X10656 . The old part number was WR55X10552 . You should call a GE representative . to see if this can be replaced under warrenty , since it was/is on a recall list . There should be a phone number in your user guide , or on the internet .
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE PFSS6PKWSS refridgerator side panel
not gonna find another manufactures product to match your dimensions, best bet is to find a local metal fabricator get a s/s panel cut to the dimension you need, silcone or a quaity double stick tape will secure it to where it needs to be
Mar 05, 2008 | GE PFSS6PKSS
Refrigerators Logo
2,737 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
